Advantages/benefits of Jet Coating turbo Manifold?
My car is on jack stands for some work I'm doing this winter so I had some downtime and I'm getting my Rev Hard Manifold and my exhaust housing off my turbo Jet-Hot coated. I know it will keep underhood temps down(I think) and won't it help the efficiency of the turbo a bit as well?
Thanks for any additional information.
M
M
Re: Advantages/benefits of Jet Coating turbo Manifold? (01ITR#700)
I believe that since it's keeping the heat IN that means you might benefit some from the exhaust gasses flowing faster...more heat energy in other words. Does that make sense?
Re: Advantages/benefits of Jet Coating turbo Manifold? (Hatchblack)
It will make a difference, but not as much as with a normal steel header. Cast iron is used for the manifold because its more heat resistant.
I am a bad person
Re: Advantages/benefits of Jet Coating turbo Manifold? (KingDsi)
the manifold will look better and it will retain more heat. I wouldnt count on any horsepower from underhood temps dropping. it gets hot as hell regardless.
civproject14
02-02-2005 08:04 PM
Midwestrider
02-05-2003 03:40 PM
