turbo ls boost problems?
Old Apr 14, 2013 | 05:22 PM
ef8sleepr's Avatar
Default turbo ls boost problems?
So, its a b18b with a t3/t4 .50 trim turbo cast manifold, greddy bov, tial wastegate, 440cc
injectors, tuned at 10 psi with chrome. made 221whp 198tq. So after the tune, went
on a couple freeway pulls. 10 psi consistantly. after the 3rd pull, boost started to taper down,
so i thought it was some sort of boost leak or exhaust leak. So, next day pressure tested it
at 25 psi, no major leaks found besides bov flange, so i rtv the flange and rechecked, no
leaks. Inspected exhaust system. full 2.5 in exhaust with a resonator, no leaks/cracks.
inspected wastegate. replaced wastegate gasket. test drove vehicle. car still boost around
3-4 psi. thought it was a bad wastegate, swapped it with my friend's brand new in box
wastegate with new fire ring, same thing. swapped turbo with same size turbo, same thing.
swapped bov, same thing. smoked tested system to make sure no leaks are present, no
leaks. checked my spark plugs ngk 7's, they look nice and dark brown. Prior to this problem
car was boosted for 9 months at 6 psi no problems. I'm running out of ideas. as of right
now, car won't boost over 2 psi. engine starts up fine, idles fine, no smoke, no rough running, does not misfire at high rpms or anything like that. it just feels like i'm boosting at 2 psi.
last thing i can think of is engine damage even though no symptoms of it what so ever. I shall do a compression check tomorrow and maybe leak down. but if anyone has some sort
of idea that can help me, that would be much appreciated. I also have a wideband installed. it's running slightly rich which is o.k but it tapers around 11 to 12 at high rpms.
Old Apr 15, 2013 | 04:37 PM
crvtectim's Avatar
Default Re: turbo ls boost problems?
Super clogged-up air filter? Lol
Old Apr 15, 2013 | 05:51 PM
hon2984's Avatar
Originally Posted by ef8sleepr
checked my spark plugs ngk 7's, they look nice and dark brown. .
post up a pic. nice and dark brown...sounds like its running rich, possibly too rich. Are you using an oem ignition coil?
Old Apr 16, 2013 | 06:18 PM
ef8sleepr's Avatar
I am using stock ignition coil. Rich would be black wouldnt they? Plus the wideband showing me stoich under boost. Maybe a little rich. But i was running way richer than this before my tune. I dont think i'm having ignition problems. I would start sputtering if i did. I just check compression. 150 psi across. I heard an unbalanced turbo can cause this symptom. Can anyone relate to this?
V-SPEC 1
Feb 19, 2013 07:43 PM
turboek97
Sep 12, 2008 12:58 AM
richboi
Apr 15, 2007 07:46 PM
MooreBoost
Aug 25, 2004 07:07 PM
Smashback
Jul 11, 2002 08:49 PM
