Turbo Ls 35 Shot: Stock Internals
Old 12-29-2002, 11:27 PM
Jdm_Rice_Monster's Avatar
Default Turbo Ls 35 Shot: Stock Internals
I am currently running a ls turbo in my crx and was thinking about running a small shot nitrous. I run 9psi and am thinking it would be a good idea to tap in on my intake pipe where my filter sits so that the spray would hit my compressor resulting in qiuck spool and at the same time cool my charge and make it more dense. I dont run a management unit right now but will be getting one asap. Has anyone else ran a setup like this or am I just crazy for tring to do such a thing on a stock motor. I dont want to turbo the boost up I just thought it would be helpful to do a setup like this. If anyone has done something simular how did you have it ran and what type of kit did you use, thanks alot.
Old 12-30-2002, 05:50 AM
silverEH2's Avatar
Default Re: Turbo Ls 35 Shot: Stock Internals (JdmRiceMonster)
yeah dude go ahead and blast a 150 shot up your ***
Old 12-30-2002, 06:15 AM
Phoenix GSR's Avatar
you have a couple problems...
first off nitrous going through your compressor will not spool your turbo... it is the byproduct of more power/exhaust once the nitrous is burned that spools quicker
the real problem is that if you use a rising rate regulator you can not use a wet shot, because it is impossible to get the fuel/nitrous mixture corect with extreme variances in fuel pressure...
if you choose a dry shot you may or may not have enough fuel... I would stay on the safe side and guess that you don't.. most dry shots raise the fuel pressure to compensate the fuel, your fuel pressure will already be raised to compensate the boost... it may work, but I wouldnt risk my motor for 35 hp...
hth
Old 12-30-2002, 09:21 AM
Default Re: Turbo Ls 35 Shot: Stock Internals (Phoenix GSR)
Slivereg6, dont you have that really fast turbod hatch, I want to race you, focker .
Well if it doesnt spool your turbo qiucker, how come alot of real fast drag cars use something along those lines, maybe it does maybe it doesnt thats ll I am tring to find out.
Old 12-30-2002, 09:54 AM
Slopoke's Avatar
Phoenix GSR already explained that in the post above yours:
"first off nitrous going through your compressor will not spool your turbo... it is the byproduct of more power/exhaust once the nitrous is burned that spools quicker"
In other words, after you burn the nitrous in your motor, the extra exhaust gases is what spools your turbo quicker. Not spraying it straight into your compressor.
Old 12-30-2002, 10:02 AM
silverEH2's Avatar
no it is not turbo, it is really slow, i got pulled on by your moms dx coupe
Old 12-30-2002, 11:21 AM
Default Re: Turbo Ls 35 Shot: Stock Internals (silverEG6)
With my mom driving it, your car is weak man. Throw the snail on quit playin around focker.
SO does anyone use nitrous on there turbo setup on stock internals.
Old 12-30-2002, 11:35 AM
B18PoweredCivic's Avatar
I was thinkin of doing that...I have a stock b18b in a civic...and was planning on shooting my NOS into the turbo...Everyone was telling me it will spool quicker...I have to do more research before I try this
Old 12-30-2002, 12:03 PM
rjardy's Avatar
Default Re: Turbo Ls 35 Shot: Stock Internals (B18PoweredCivic)
what the hell is going on in here?!?
rob
Old 12-30-2002, 02:31 PM
tygsr's Avatar
Default Re: Turbo Ls 35 Shot: Stock Internals (rjardy)
How bout you take the money you would spend on the nitrous kit and get a fuel management system, that 35 extra hp could be made on a dyno...what size injectors are you running??
Old 12-30-2002, 03:04 PM
silverEH2's Avatar
Default Re: Turbo Ls 35 Shot: Stock Internals (tygsr)
that sounds like a good idea jdmricer, go ahead and get a management system, while your at it sell me your fmu and fuel pump.
Old 12-30-2002, 08:51 PM
I am getting a management system and nitrous. My fmu, cafc, and inline area all going to be gone. Obd1 conversion s200 hondata will be in the mix very soon.
dorado_mike
08-06-2010 04:33 AM
Unknown Racing
03-12-2007 03:04 AM
nxda9
07-24-2005 05:52 PM
NIAScrew2
07-26-2004 11:41 AM
o.G.A.g.
08-07-2002 01:28 PM
Quick Reply: Turbo Ls 35 Shot: Stock Internals
