turbo kit
Old May 29, 2006 | 12:06 PM
Speed Infliction's Avatar
Default turbo kit
What is a good turbo kit to get around 3 grand. I am new to this and not sure. I have a 2001 ITR. I also have eagle h beam rods and not and JE 10:1 compression pistons. Thanx in advance
Old May 29, 2006 | 12:20 PM
SiR99's Avatar
Default Re: turbo kit (Black Mamba)
Just do some research and part together your own kit. You'll get better parts, make more power, and it will most likely cost you less. With the research you do, you can install it yourself too, all you will need to do is find a good tuner after that
Old May 29, 2006 | 12:35 PM
Default Re: turbo kit (SiR99)
I found one on ebay for 1800 bux. Its a turbonetics. Do you think that is a good one and for the price?
Old May 29, 2006 | 01:14 PM
Autoworks's Avatar
For $3k...build your own with a good fuel management and you'll save alot of $$.
Old May 29, 2006 | 03:37 PM
SiR99's Avatar
The thing is, even if you buy the turbo kit your going to need small parts like cam gears, 255 fuel pump, head gasget, slim fan, intercooler piping that fits your turbo, high flow cat/test pipe, and then your going to need a chipped ecu and tune it all. All that stuff adds up, so if you try to build your own kit, you will stay in your limit of $3000 or spend even less.
For example, you can buy a log manifold kit, which is $100 bucks, and weld it together yourself, and right there you save around $200 bucks from buying an already assembled one which is around $300. You can do the same for the downpipe. You can also buy an Ebay intercooler which is around $100 bucks and an ebay type S blow off valve which is like $40 shipped. Then you can get some dsm injectors for $60. This are some examples of how you can save some BIG money.
I dont see you staying in your limit if you go with a kit, cause theres other things you have to do to the set up to make it run reliably
MrArney
Feb 20, 2013 06:47 PM
VTEC+Mini
May 3, 2012 02:59 PM
xkrntamax
Jan 12, 2008 02:05 PM
1JDMDOMINICAN
Dec 20, 2004 06:43 AM
v-attack
Apr 10, 2003 04:12 PM
