Turbo ITR Problems
Old Mar 21, 2006 | 05:41 PM
  #51
jDMJeRk's Avatar
Default Re: (VtecKiDD)
UPDate?
Old Mar 21, 2006 | 06:51 PM
  #52
nwmotorsports's Avatar
Default Re: (jDMJeRk)
Ive had bad o-rings on the 2 vtec jets on the drivers side of the head go bad. They were not holding the pressure causing the rockers not to lock. Hope this helps.
Old Mar 21, 2006 | 08:32 PM
  #53
SL0WEGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">
Terry ill check the clogged cat, good thinking , that never even crossed my mind.
there was a local kid with an n/a 00si that ran like complete *** during the vtec changeover and he couldnt figure out what it was. Turned out it was a clogged cat. so thats a big possibility in this case. good luck!
Old Mar 21, 2006 | 08:59 PM
  #54
TheShodan's Avatar
Moderator
Default Re: (Meat_Wagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Meat_Wagon &raquo;</TD></TR><TR><TD CLASS="quote">I have seen similar graphs when the timing belt is a tooth off.</TD></TR></TABLE>
Dealt with that a couple of days ago on a client car as well. When the timing belt was properly adjusted and set, it made a WORLD of difference.
Old Mar 21, 2006 | 09:13 PM
  #55
Lvnit's Avatar
Same problem with my turbo b16, would boost nice and then die in the **** for some reason.
Was a clogged cat converter, took it out, fixed everything up
Old Mar 21, 2006 | 09:46 PM
  #56
VtecKiDD's Avatar
Default Re: (Lvnit)
ill be putting it back together tomrrow, ill keep everyone updated, thanks for all the advice
Old Mar 22, 2006 | 12:52 AM
  #57
92gsrteg's Avatar
Default Re: Turbo ITR Problems (VtecKiDD)
cam timing, i'd take apart the head and make sure everything is lined up tdc(crank pulley, camgears), make sure u have the right cam on the right side(intake cam on intake side and vice versa), and then set ur timing at 16 degrees and go from there. hope this helps bye, also check ur timing on ur tune, should retard about 1 degree for each pound of boost or somethin like this, please correct me if im wrong. thanks
Old Mar 22, 2006 | 12:51 PM
  #58
abnaasefmb's Avatar
Default Re: Turbo ITR Problems (92gsrteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92gsrteg &raquo;</TD></TR><TR><TD CLASS="quote">cam timing, i'd take apart the head and make sure everything is lined up tdc(crank pulley, camgears), make sure u have the right cam on the right side(intake cam on intake side and vice versa), and then set ur timing at 16 degrees and go from there. hope this helps bye, also check ur timing on ur tune, should retard about 1 degree for each pound of boost or somethin like this, please correct me if im wrong. thanks</TD></TR></TABLE>
that's funny
Old Mar 22, 2006 | 01:04 PM
  #59
I Have an STD's Avatar
wrenchin'
yer telling a tuner/engine builder how to tune/build a motor. thats like me telling Burns stainless about welding.
get a rope
Old Mar 22, 2006 | 02:54 PM
  #60
itr1143's Avatar
my boosted type r did the same thing..ran great ,made good power till v-tech..then broke up and ran like ***...was the coil..
Old Mar 22, 2006 | 02:56 PM
  #61
Boostfed's Avatar
New User
I was gonna say something about the above post where the guy said to make sure teh Intake Cam is on the intake side and vice versa!!! hahahaahah
Old Mar 22, 2006 | 03:12 PM
  #62
.nate's Avatar
Have you swapped a known good dizzy on the motor to rule that out as a possibility?
Old Mar 22, 2006 | 04:01 PM
  #63
Meat_Wagon's Avatar
Default Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">I was gonna say something about the above post where the guy said to make sure teh Intake Cam is on the intake side and vice versa!!! hahahaahah </TD></TR></TABLE>
Yeah who hasn't had that problem before, lol. I always run two intake cams.
Old Mar 22, 2006 | 04:12 PM
  #64
abnaasefmb's Avatar
fuc|&lt;ing leg!!!!
i was going to say coil, but it would show as lean spikes and the A/f looked good.
i once had a stock cam gear that was off about five deg.
Old Mar 22, 2006 | 04:22 PM
  #65
Boostfed's Avatar
New User
Default Re: (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">
fuc|&lt;ing leg!!!!
Dude get the expletive outta here, I have 35 jumps and over 3500 chutes packed, don't hate cuz you're a CHERRY, 5 Jump Chump, you da LEG! lol
Old Mar 23, 2006 | 06:53 AM
  #66
VtecKiDD's Avatar
Default Re: (.nate)
We put it all back together, everything looked in working order. i cleaned all the passages and we got a new solenoid.
I will check the distributor today.
NO CATALYTIC converter on this car, i forgot, he runs our 3in mandrel exhaust, so thats not it.
Cam timing is perfect.
Both exhaust cams are lined up perfectly
Old Mar 23, 2006 | 06:59 AM
  #67
Boostfed's Avatar
New User
Doh I was crossing my fingers for the simple fix!!!!!!!!!!!!!!
Old Mar 23, 2006 | 10:41 AM
  #68
civic93@8psi's Avatar
FIXED YET???
weird problem would like to kno the problem
-mike
Old Mar 23, 2006 | 09:52 PM
  #69
VtecKiDD's Avatar
Default Re: (civic93@8psi)
Dynoed it tongiht, SAME PROBLEM is still evident.
Replaced the distributor and the vtec solenoid as well. cant figure it out. im lost
Old Mar 23, 2006 | 10:03 PM
  #70
btotherizzle's Avatar
burn that ****. type r's suck
Old Mar 24, 2006 | 04:38 AM
  #71
BoostedEG6's Avatar
Default Re: (btotherizzle)
I dont know if this could be the problem but have you checked the fuel filter? maybe that could have some junk in it? I dunno just a thought tho..... strange problem
Old Mar 24, 2006 | 04:43 AM
  #72
RTW DC2R's Avatar
Default Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btotherizzle &raquo;</TD></TR><TR><TD CLASS="quote">burn that ****. type r's suck</TD></TR></TABLE>
qft
Im about to boost my R, I wanna know wtf the problem is. Could something like this be electrical or other sensor related(besides VTEC Solenoid)?
edit: quoted the wrong person
Modified by RTW DC2R at 12:03 PM 3/24/2006
Old Mar 24, 2006 | 07:46 AM
  #73
VtecKiDD's Avatar
Default Re: (RTW DC2R)
I would think the Fuel Filter would shop up in the a/f ratios.
but at this point ill check it out
im gonna pull the turbo off and put a header on it and see what the power does
Old Mar 24, 2006 | 08:05 AM
  #74
yee SERIOUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">im gonna pull the turbo off and put a header on it and see what the power does</TD></TR></TABLE>
yeah, how come no one ruled out a bad turbo?
Old Mar 24, 2006 | 08:22 AM
  #75
VtecKiDD's Avatar
Default Re: (undercoverdc2)
well, heres my thinking:
if it was seals, there would be oil there is none
it holds boost so i would ASSUME the turbo is functioning
