Turbo ITR Problems
Old Mar 17, 2006 | 07:01 PM
  #26
abnaasefmb's Avatar
Default Re: (VtecKiDD)
What are you tuning with? what timing are you running? A bad ignitor will break up like that but would show as a lean spikes. Is the wiring harness sound? What is the map sensor reading? Keep us posted!
Old Mar 17, 2006 | 07:46 PM
  #27
Muckman's Avatar
Moderator in Chief
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">have u tried to shut off vtec and make a full pass without it?</TD></TR></TABLE>
Thats a good idea. I bet you the dyno will look identical too.
Old Mar 17, 2006 | 08:21 PM
  #28
RTW DC2R's Avatar
what ECU?
Old Mar 17, 2006 | 08:26 PM
  #29
VtecKiDD's Avatar
Default Re: (RTW DC2R)
LOW CAM Pulls are IDENTICAL TO VTEC PULLS.
ECU an TUNING IS NOT THE PROBLEM. Timing is fine, plugs are gapped. its a mechanical problem.
Im going to dissasemble the rocker arms tomrrow. The pins are sliding over, but they are not staying LOCKED. this is the weirdest **** i have ever seen.
Old Mar 17, 2006 | 09:17 PM
  #30
Sketch_hs's Avatar
in for results!
maybe check valve adjustment?
Old Mar 17, 2006 | 09:53 PM
  #31
JDM00SI's Avatar
Default Re: (Sketch_hs)
subscribed to this thread....
Very wierd....
Old Mar 17, 2006 | 10:16 PM
  #32
D@nnY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">LOW CAM Pulls are IDENTICAL TO VTEC PULLS.
Im going to dissasemble the rocker arms tomrrow. The pins are sliding over, but they are not staying LOCKED. this is the weirdest **** i have ever seen. </TD></TR></TABLE>
trying to engage vtec with air isnt the same as oil...air compresses oil doesnt...the motor uses oil pressure to "lock " it into vtec.... you may have fucked up bearings or a bad oil pump
did you check if the oil jets are there under the cam caps? when did this problem start happening? is the oil jet in the block ? are any of the orings bad? do you have the wrong cam gears on the cams? who built the motor ?
Old Mar 18, 2006 | 06:43 AM
  #33
VtecKiDD's Avatar
Default Re: (D@nnY)
140psi of air pressure is enough to lock the pins in vtec, i have done it on another car before.
Oil pump is brand new, bearing clearances are within spec (i built the motor). Piston to wall clearance is in spec. oil restrictors are in the head, everything is there that is sposed to be PER the honda service manual.
Im going to do more investigating today/tomrrow. I have a test i want to do ill keep you guys updated
Old Mar 18, 2006 | 06:57 AM
  #34
JDM00SI's Avatar
still awaiting updates....
very weird problem.
Old Mar 18, 2006 | 08:38 AM
  #35
Quad-Damage's Avatar
Default Re: (JDM00SI)
crazy
Old Mar 18, 2006 | 11:27 AM
  #36
VtecKiDD's Avatar
Default Re: (Quad-Damage)
Looks like the Exhaust an Intake Rocker arm SHAFTS are wrong. But i cant find part numbers for the shafts.
The honda service manual has a picture describing the rocker arm shafts, it looks BY the diagram that this head has 2 of the same EXHAUST rocker shafts.
anyone know if the shafts are different? some people say they arent, some people say they are, i cant din part numbers
Old Mar 18, 2006 | 12:10 PM
  #37
EM2Civic's Avatar
The shafts are number 6, they seem to have the same part number. Hope it helps.
Part number 006 14631-PR3-000
Modified by EM2Civic at 8:47 PM 3/18/2006
Old Mar 18, 2006 | 12:39 PM
  #38
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">in for results!
maybe check valve adjustment?</TD></TR></TABLE>
thank you. please try a valve adjustment
Old Mar 18, 2006 | 12:45 PM
  #39
Sketch_hs's Avatar
Default Re: (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">thank you. please try a valve adjustment </TD></TR></TABLE>
it can make a big difference!
Old Mar 18, 2006 | 01:29 PM
  #40
*Boostwerks*'s Avatar
But if his compression is 200 accross, I doubt thats the problem.
hrmm.
Old Mar 18, 2006 | 02:18 PM
  #41
siblueg's Avatar
Default Re: (Bryson)
find a answer?
Old Mar 18, 2006 | 04:56 PM
  #42
si0385.'s Avatar
subscribed...
this is a weird problem
Old Mar 18, 2006 | 07:50 PM
  #43
Boostfed's Avatar
New User
Mike, does this car have a cat on it?
Old Mar 18, 2006 | 09:17 PM
  #44
SPOOLINmatt's Avatar
Default Re: (Boostfed.com)
+1 for a possible blown up cat?
Old Mar 18, 2006 | 09:33 PM
  #45
jDMJeRk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">Mike, does this car have a cat on it? </TD></TR></TABLE>
You would think it would start to smell if it did... But yeah good question...
Old Mar 18, 2006 | 09:56 PM
  #46
wpgcivic's Avatar
do a compression test
Old Mar 18, 2006 | 10:17 PM
  #47
JDM00SI's Avatar
stiill awaiting results
Old Mar 19, 2006 | 02:06 AM
  #48
MidShipCivic's Avatar
Default Re: (wpgcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">do a compression test</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECKIDD &raquo;</TD></TR><TR><TD CLASS="quote"> Compression was 200-200-200-200</TD></TR></TABLE>
Old Mar 19, 2006 | 03:25 AM
  #49
DaveF's Avatar
Default Re: (MidShipCivic)
turbo ITR
10:1 JE pistons </TD></TR></TABLE>
notice the 200 across cyl pressures. anyone else think it should read a bit higher?
do a leakdown test.
( I still think a valve adjustment is in order.)
Old Mar 19, 2006 | 08:37 AM
  #50
VtecKiDD's Avatar
ill keep everyone updated. The exhaust Rocket shaft was VERY hard to pull out, i spoke with someone at ACURA and they said it was possible to have a bent shaft, they have had it before. So il be getting new rails.
Valve adjustment was done 6intake 8 exhaust. Compression test was 200psi across the board, which is perfect for a 10:1 motor IMO.
Motor does NOT smoke, has no blow by out of the exhaust or valve cover breather. Has 70psi of oil pressure AFTER vtec engages. so there is oil pressure.
Its something to do with the Rockers, Vtec Solenoid, etc. Something in the VTEC system.
Terry ill check the clogged cat, good thinking , that never even crossed my mind.
