Turbo Installed, Check Engine light at 2.1k RPM
Installed Hondata s200b and everything else needed for my turbo. Car runs fine, boosts nice, problem is that it throws a CEL after 2000 rpm. Anyone know what that could be?
Re: Turbo Installed, Check Engine light at 2.1k RPM (Mase)
There is a laundry list of things that could be wrong! Are you boosting over 11psi? I believe that will throw a CEL.
Re: Turbo Installed, Check Engine light at 2.1k RPM (MadCow)
actually im too afraid to check the ECU with a brick on the gas holding it above 2k rpm because no one else helping me on it, i was just curious if this was a common problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">you arent boosting on a basemap are you?</TD></TR></TABLE>
Nope
Nope
Re: Turbo Installed, Check Engine light at 2.1k RPM (cdog19)
I had a problem with mine doing that and found out it was the set button.When I tried to set the limits full throttle shift was being set at 12,xxxrpms.So I called Hondata and they told me to set all of my rev-limits in Hondalogger and that got rid of the CEL above 2000.
Re: Turbo Installed, Check Engine light at 2.1k RPM (imblown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imblown »</TD></TR><TR><TD CLASS="quote">I had a problem with mine doing that and found out it was the set button.When I tried to set the limits full throttle shift was being set at 12,xxxrpms.So I called Hondata and they told me to set all of my rev-limits in Hondalogger and that got rid of the CEL above 2000.</TD></TR></TABLE>
I think i figured out problem from the guy that had the kit previously, he just never changed his shift-light (which happens to be the CEL) from 2000rpm, lucky me my engine is fine!
GsrRussell
09-24-2008 08:32 AM
trooper0641
01-13-2006 08:07 PM
xXx Justin xXx
16
05-26-2003 03:29 PM
