OBD1 clips with DSM 450's
Old Jan 21, 2004 | 10:26 PM
APEXI Si's Avatar
Default OBD1 clips with DSM 450's
I have heard that if you tirm the little piece on the inside of the injector.. they fit well in to 0bd1 injector clips.
I search all over and this is the best Post i could find.
https://honda-tech.com/zerothread?id=460459
The post got confusing at the end. So please help me and everyone else bring this to a conclusion.
Thanks
Old Jan 22, 2004 | 03:17 AM
T-RO's Avatar
Yes just cut down that piece INSIDE the injector to get them to fit.
Dont cut the tabs that are on the side cause thats what holds them in the injector clips.
(Shameless plug here--&gt PS If you need a Resistor box I have some for sale. Mine have the OEM connector on them for a solderless install. PM me.
Old Jan 22, 2004 | 06:01 AM
mike1114's Avatar
Default Re: (T-RO)
inside top part of injector, in the middle there is a plastic guide for when you put the clip on.
Take a blow torch and a coat hanger, heat up the coat hanger on one end and when it is red hot, melt out the little tab in the top of the injector. Do that to each one and they stock honda obd1 clips go right on perfectly.
I did this and have not had any problems what so ever.
Edit: in the link you posted, the part you cut out is numbered 3.
Old Jan 22, 2004 | 07:21 AM
T-RO's Avatar
Or if you dont have a blow torch in your garage you can use an Exacto blade. Thats what I used.
Old Feb 21, 2004 | 02:43 PM
Black R's Avatar
25 Year Member
Default Re: (T-RO)
..... what injector clips are you guys referring to? obd1 or obd2?
Old Feb 21, 2004 | 03:18 PM
Johnyquest's Avatar
Default Re: (Black R)
It's pretty simple. You just cut the tab. Put the clip next to the injector, analyze. Realize that the tab is the obstruction. Remove tab. Use as normal!
Old Feb 21, 2004 | 03:41 PM
warwagon's Avatar
Default Re: (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">It's pretty simple. You just cut the tab. Put the clip next to the injector, analyze. Realize that the tab is the obstruction. Remove tab. Use as normal! </TD></TR></TABLE>
for some odd reason i laughed
Old Feb 21, 2004 | 03:50 PM
T-RO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">..... what injector clips are you guys referring to? obd1 or obd2? </TD></TR></TABLE>
They are talking about OBD1 clips. OBD2 clips dont fit at all so you would have to switch to OBD1 or OBD0 clips instead.
P.S. I have a set of OBD0 injector clips in the for sale if anyone needs some.
white98gs-r
May 15, 2009 10:43 PM
nix94delsol
Apr 7, 2009 02:29 AM
.adam.
Aug 16, 2006 11:16 AM
petergriffen
Jul 17, 2006 08:48 AM
thedirty-Dseries
Apr 1, 2006 02:34 PM
