OBD1 Injector clips?
Everywhere Ive read it says all of the obd1 injector clips are the same, but trying to plug them in, and having them not go in leads me to believe otherwise. Since the new search feature sucks, il explain
D15b7 injector clips on an H23a. Both are OBD1, what am i missing here? is it only MY injector clips that wont fit, due to the fact the motors so small?
Re: OBD1 Injector clips?
What the ****. the injector clips wont go onto the injector. im inside an its pouring out sooo. are they injector specific? as in, will injector 1 only go in clip one injector 2 will only go in clip 2 ect.?
thanks for the help though!
it used to point you right to a point of what you needed, so that way there are less new threads.
no thery're all the same. should fit if u say everything is obd1. if h23 injectors are obd2 then i know your problem. not sure if h23 uses peak n hold but not sure if that would make a difference with clip fitments....
