IC couplers...
Old Jan 28, 2007 | 02:47 PM
Ben Ogle's Avatar
Default IC couplers...
So I am looking around for couplers but I am having problems. From TB to turbo, here are the sizes I need:
2.5 (2.7@rib)->2.25, 2.25->2.25, 2.25->2.5(ic), 2.5(ic)->2.0, 2.0->1.5(maybe 2" @ turbo)
Here are the main options I see:
Rubber Plumbing couplers
They dont have any that fit anything. The 2.0" (the plumbing couplers are measured for the ID of the PVC they fit over, so 2" coupler has ~2.5" ID) couplers fit the TB, but thats it. I can clamp them down a ton to fit the 2.25 pipes, but I dont want to do that. Also, I cant get the 1.5" couplers over the 2.0" pipe. And sizes in .25" increments dont exist (1.75" please?). Ugh. $3.50/piece.
Silicone couplers
I can get all the stuff I need, but its crazy expensive. I am fine paying $6 a piece for the straights, but I need 4 transitions and they are ~$18 a piece (@ atp turbo anyway)!! Then I'll need 10 clamps ($3/ea at napa). So It'll be roughly 6+18*4+ 10*3 = $108!!
Does anyone have any other solutions? I'm sure there are folks running small IC piping like this. What did you do about all the transitions?
Ben
Old Jan 28, 2007 | 02:49 PM
y7turbo's Avatar
Default Re: IC couplers... (Ben Ogle)
http://www.siliconeintakes.com/
i go here for all my couplers.
Old Jan 28, 2007 | 02:54 PM
BlackBeastEK's Avatar
spoolinperfromance.com has couplers you can check them out
Old Jan 28, 2007 | 03:08 PM
broketuner-Sol_Si's Avatar
Default Re: (elementb16a)
I got mine from LSD motorsports for 78 shipped with T bolt clamps I ordered: 2 2.5-2.25 reducers, only 1 2.25" coupler, 1 2.5"-2" coupler, and 2 2" couplers. and all the neccesary clamps
Old Jan 28, 2007 | 03:09 PM
Ben Ogle's Avatar
Default Re: IC couplers... (y7turbo)
You're a badass. I am fine paying $11/ea for the transitions. And I realized I only needed 3... Order placed at http://www.siliconeintakes.com/.
Ben
Old Jan 28, 2007 | 03:59 PM
Bailhatch's Avatar
if you plan out your setup better you wont need more than one or 2 reducers at most. I have one on mine, just coming out of the turbo.
If you can weld, you can use pre-expanded pieces of tube to bring the end of each section up or down to the next one. metal is WAY chaper than silicon
Old Jan 28, 2007 | 04:42 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ben Ogle &raquo;</TD></TR><TR><TD CLASS="quote">You're a badass. I am fine paying $11/ea for the transitions. And I realized I only needed 3... Order placed at http://www.siliconeintakes.com/.
Those will probably work for you, but just to clarify a few things. Those are purely silicone couplers.....soft rubber style that will wear out and have a tendency to get ripped or torn when clamping down. Hoses from a company like http://www.turbohoses.com have fiberglass reinforcements to keep the coupler from getting killed. That is one of the primary reasons the hose you found are so cheap in comparison to others out there.
Old Jan 29, 2007 | 08:45 AM
Ben Ogle's Avatar
Default Re: IC couplers... (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">if you plan out your setup better you wont need more than one or 2 reducers at most. I have one on mine, just coming out of the turbo.
If you can weld, you can use pre-expanded pieces of tube to bring the end of each section up or down to the next one. metal is WAY chaper than silicon</TD></TR></TABLE>
Meh. I went with different small piping for a reason. I can weld, but the silicone is cheaper than my time and argon. Plus I couldnt do any welding to help my need for 3 reducers. I'm not about to weld a reducer onto the IC or the TB.
Blown90hatcH, thanks. I totally didnt see that. Oops. I think they will work for the time being. I will just be careful.
Ben
Old Jan 29, 2007 | 08:57 AM
Turbo-LS's Avatar
http://WWW.Hightempsilicone.com
Awesome couplers, very strong, havent had any issues with them and there 3 and 4 layer 300-500 degree temp ratings. kinda pricey but well worth the money. there tbolt clamps are kick *** too
Old Jan 29, 2007 | 12:40 PM
HiProfile's Avatar
Default Re: IC couplers... (Turbo-LS)
I just got 48" of 2.25" ID 4-ply silicone hose for $32 shipped off ebay. Thats $0.67/inch. You can also find quality SS t-bolt clamps for ~$2/ea off of ebay. The ones I got a year ago really supprised me - etched onto them all was "Made in Ohio, USA".
If you look carefully, that silicone intakes place uses 3 or 4ply fiber-reinforced hoses. As long as it's 3-ply silicone, it can easily take 10psi from a normal honda setup.
Old Jan 29, 2007 | 02:00 PM
Bailhatch's Avatar
good call, ive only build about 4 miles of IC pipes. good luck with your lumpy, expensive pipes
Old Jan 29, 2007 | 02:16 PM
Ben Ogle's Avatar
Good for you!
Ben
Old Jan 29, 2007 | 03:00 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-LS &raquo;</TD></TR><TR><TD CLASS="quote">http://WWW.Hightempsilicone.com
Awesome couplers, very strong, havent had any issues with them and there 3 and 4 layer 300-500 degree temp ratings. kinda pricey but well worth the money. there tbolt clamps are kick *** too </TD></TR></TABLE>same ones i use
Old Jan 29, 2007 | 06:03 PM
LSTDB8's Avatar
very nice couplers but i had some customer service issues with them
PURPLERANGER
Jun 24, 2012 01:58 PM
all_motor_mike
Welding / Fabrication
Sep 13, 2009 11:16 AM
EJ8 GSR-T
Dec 24, 2005 04:17 PM
InTeGrA B18b1
May 20, 2003 12:50 PM
CalvitoSol
Jun 8, 2002 12:36 AM
