2.5 V-Band Downpipe? Where to get?
I'm currently looking at getting a turbo that has a 2.5 V-Band Outlet, but seem to have a hard time finding a Downpipe that will fit it, or for that matter, having a hard time finding much info about the 2.5 V-Band Outlet. Could someone throw me in the right direction on how this Turbo would fit on the Downpipe or if there is an Adapter I need.
Re: 2.5 V-Band Downpipe? Where to get?
if the turbo already has a v-band outlet then you can add a 2.5" flange to the downpipe seen here - http://www.atpturbo.com/mm5/merchant..._Code=ATP-FLS3
and then the clamp to hold them together here - http://www.atpturbo.com/mm5/merchant..._Code=ATP-FLS3
i dont know if you will find a pre-constructed downpipe with v-band so you may need to cut of the regular 2.5" flange and weld on the v-band.
