boost leak?? no idea
Old Sep 18, 2006 | 09:57 PM
playahwitgame's Avatar
Default boost leak?? no idea
ok so i foun dout i had a boost leak in my ic piping. i replaced the piping and there isnt a leak but i still cant boost my 7psi. i hooked up the manual boost controller and on the lowest setting (turbosmart dual stage) and it over boosts like hell. this is pissing me off. how do you know if a wastegate is bad?
Old Sep 18, 2006 | 10:10 PM
mtber's Avatar
Default Re: boost leak?? no idea (playahwitgame)
You probably have your boost controller connected improperly or you are adjusting it improperly.
Old Sep 19, 2006 | 06:07 AM
Default Re: boost leak?? no idea (mtber)
its really imsplt . arrow pointg towards the wastegate and it has dials on it. but noe the less, even if i take off the boost controller, it wont reach full boost
Old Sep 19, 2006 | 06:09 AM
Snafubmx234's Avatar
Don't worry about your boost controller, it's definately operator error.
Secondly, how much boost is your car making without the boost controller? Are you sure you have a 7psi gate? Internal or external gate? You need to tell us more information.
Old Sep 19, 2006 | 09:08 AM
Default Re: (Snafubmx234)
how would it be operator error????? it says put inline with the wastegate line and have the arow facing the wastegate. and thats how i did it.
red 7psi spring. on the dyno it was holding 7psi fine. also a few days after the dyno it held fine, out of nowhere it wasnt acting right. i pressur etested the system and found a hole in the pipe coming off the turbo. and i replace ALL the intercooler piping. im going to pressure test it again. i bet you i wont find anything
ericstambaugh07
Jun 23, 2007 09:04 AM
faSHOwidIT
Jan 31, 2007 03:51 PM
GDM Z28
Nov 30, 2003 06:13 AM
teamrocket si
Feb 10, 2002 02:27 PM
SIK IN DA HED
Sep 13, 2001 03:16 AM
