do i need this?
Old Jul 1, 2002 | 01:49 AM
KLN's Avatar
KLN
Default do i need this?
what is the port on the side of the turbo for? i've tried to search and find out if i need it...
is it important? because right now i have nothing in that hole on the side of the turbo, i took the fitting out
Old Jul 1, 2002 | 01:59 AM
qwkteg125's Avatar
Default Re: do i need this? (KLN)
you can use that as a boost reference for your wastegate.
Old Jul 1, 2002 | 02:02 AM
KLN's Avatar
KLN
Default Re: do i need this? (qwkteg125)
but, is it ok if i just leave it open with no fitting in it?
Old Jul 1, 2002 | 02:03 AM
Ri5e's Avatar
you can plug it up and just use the intake manifold source.
Old Jul 1, 2002 | 03:17 AM
rjardy's Avatar
plug it, it will bleed boost.
Rob
Old Jul 1, 2002 | 06:27 AM
CovertFI's Avatar
Default Re: do i need this? (rjardy)
the teflon on your oil fittings are gonna leak.
Old Jul 1, 2002 | 06:31 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: do i need this? (BG Boost)
How bout using that hole instead? Wouldn't the readings be a little more accurate since it's coming right from the compressor? Straight line to the WG.
Old Jul 1, 2002 | 06:55 AM
Rain_man's Avatar
New User
Default Re: do i need this? (shamoo)
Actually, boost measured from the manifold will take into account the pressure drop due to the intercooler, which should mean your wastegate can stay closed a little bit longer. There is a benefit to reading boost off the compressor as well but I forget.
Old Jul 1, 2002 | 07:02 AM
CovertFI's Avatar
Default Re: do i need this? (DarksideDC4)
you will notice a diffrence between locations i did. felt like a quicker spool and i ended up boosting more. (because of ic pressure drop)
Old Jul 1, 2002 | 08:14 AM
TurboCivicSi's Avatar
Correct.. Read boost at manafold, but control boost at the compressor.. When your turbo begins to soar up in revs, you want your gate to open as quickly as possable..
DO NOT leave this port open!! You will bleed boost and posably over rev your turbo.
The teflon tape on your oil fitting will burn up, and can make it's way into your bearing.. You have to get it out of there..
See ya,
-Jason
Old Jul 1, 2002 | 10:03 AM
*Boostwerks*'s Avatar
Default Re: do i need this? (CovertFI)
What?
Mine havn't....and that's been over 6 months of daily driving.
Old Jul 1, 2002 | 11:11 AM
KLN's Avatar
KLN
Default Re: do i need this? (Bryson)
thanx for all the replies...by the way, that is not a picture of my setup. i believe it is from dustin's webpage on his turbo install...it was very helpful...thanx
Old Jul 1, 2002 | 11:16 AM
CovertFI's Avatar
your lucky then. i have to use the red rtv sealent
Bartman201
Nov 2, 2005 10:42 AM
sir00
Feb 16, 2005 06:43 PM
underpressure02
Oct 6, 2003 08:14 AM
Teg4e
Jul 3, 2002 09:01 PM
b18tdelsol
May 31, 2002 12:21 PM
