Turbo oil Feed Location?
im going to be putting a turbo on my B16A2 eg civic and im trying to find out where will be a good place to locate the turbo oil feed line from the engine?
If anyone could help it would be most appreciated. It would be great if you have pics too?
Thanks
Chris
Thanks
Chris
Re: Turbo oil Feed Location? (wantboost)
didnt quite understand if u wanna know where to get the oil from but here is how u hook up your oil feed line
https://honda-tech.com/zerothread?id=1263795
Re: Turbo oil Feed Location? (RedR)
I wouldnt run the oil pressure switch "T".. In my opinion it adds too much weight just hanging off the back of the block.. What I do it get a 1/8"BSPT to 1/8"NPT fitting and screw that into the oil pressure fitting on the back of the block.. And then run a line from that into a oil block(get them from mcmaster.com) And put the stock oil pressure sensor and turbo feed line comming from the block.. Mount the block on to the firewall..
totsie7944
05-01-2008 04:52 AM
