Turbo exhaust housing removal
Hey I'm having a hard time trying to remove the exhaust housing. I've tried smacking it against everything, pb blaster, and I have a 1lb mallet I've been using. I've removed 4 of the 6 bolts, the other 2 the center section is in the way to remove them all the way but they are loosened. Any tips would help. Thanks.
Who is Mr Robot?
Re: Turbo exhaust housing removal
Until those two bolts come out it won't come off... Clamp the center section in a vice and put a pry bar in the turbine inlet to spin it.
.if the housing still won't come off gently heat the mounting surface then try to tap it off... Slowly because if you hit it and it comes off wrong you'll damage the turbine wheel
You will need to torch the turbine housing to heat it up well, and light hits with a hammer downwards (away from the CHRA) should break the seal. Afterwards, you should be able to spin it and remove the two bolts fully.
K thanks. I just tried to spin it with someone with a steel bar in the compressor outlet and me with 1 in the exhaust outlet and no luck, we actually bent 1 of the bars. I'll have to get a torch then.
GEN2 LS
09-17-2016 02:29 PM
zojirushi
12-02-2002 08:54 AM
