Clocking Turbo Exhaust Housing
hey, im currently in the middle of a turbo build.. im having trouble clocking my exhaust housing side. I sprayed it with lubricant to kinda soak it a bit, and it just wont budge. Seems like its just seized to ****, and wont budge anywhere. Any ideas or help? Im desperate i wanna just get this thing done. Thanks!
Re: Clocking Turbo Exhaust Housing
Is it new or used? Sometimes heating up the housing a little bit helps as well as tapping it with a hammer. If it's used, you might have to heat it up, and tap the **** out of it with a BFH. Use a block of wood or something to dampen the hits so you don't damage the center section/housing.
Its used. And yes ive literally taken off all the bolts. I guess ill haveto try heating it up, and using a rubber mallet.
Unless anyone has any other ideas!
But anyways, thanks alot guys ill haveto give it a shot.
you could try sticking the back end of the mallet/screwdriver into the compressor outlet to get some leverage on the housing
GEN2 LS
09-17-2016 02:29 PM
yellowturbo
02-11-2005 11:26 AM
TurbothisLS
02-19-2004 05:53 AM
