Turbo ef hood issues
Old Apr 4, 2011 | 07:34 AM
spoon93's Avatar
Default Turbo ef hood issues
So I have a turbo ef si hatch the problem I's the sits on my wastegate anyone else have this problem if so how can I fix it wats a goo route? Thanks
Old Apr 4, 2011 | 07:35 AM
you449's Avatar
Default Re: Turbo ef hood issues
Post some pics wht exactly is wrong
Old Apr 4, 2011 | 08:04 AM
spoon93's Avatar
pics
Old Apr 4, 2011 | 08:08 AM
spoon93's Avatar
The drive side I also cut tHe inside but still and it crack the top of my cf hood
Old Apr 4, 2011 | 08:19 AM
JdmKrew209's Avatar
would a jdm hood work?
Old Apr 4, 2011 | 08:26 AM
spoon93's Avatar
Not sure I wonder If others have this same prob
Old Apr 4, 2011 | 08:28 AM
JdmKrew209's Avatar
can you adjust your turbo or something to make it lower?
Old Apr 4, 2011 | 08:40 AM
spoon93's Avatar
Nah I can't it's weird I'm running a log manifold and a tnetics deltagate wonder if the tial wastegates are smaller
Old Apr 4, 2011 | 08:48 AM
spoon93's Avatar
Can I adjust the latch mAybe?
Old Apr 4, 2011 | 09:19 AM
slowassBubble's Avatar
different turbo manifold or get an internal wastegate, or u might get away with getting a smaller wastegate, or u can relocate ur wastegate...or try lifting ur hood from the the back....if it was my car i would just relocate the wastegate, u can fab up a pipe urself and weld it if u have welding access or take it to a shop they couldnt chage u anymore than 80 bux to move the wastegate
Old Apr 4, 2011 | 09:32 AM
tooslohatch's Avatar
I had this same problem when i used my old log manifold. The wastegate would hit the hood and i couldn't close the hood at all. I bought two wastegate flanges from ATPturbo.com. I ten welded a 90 degree peice of tubing between them (you can order a 90 dergee piece or make pie cuts). This placed the wastegate off to the side and actually made it a bit easier to recirculate the exhaust. Shimming the hood in the back wony be anough because the motor moves a good bit while driving hard. Neither can you move the latch without getting a gap between the hood and filler piece. Hope this helps!
-Micah
Old Apr 4, 2011 | 09:33 AM
dephtone's Avatar
I have a Tial 38mm Wastegate that sits on top of a Inline Pro Manifold and I was able to cut the webbing out of my hood to get it to fit, in your situation though, I would get an elbow that will move it out of the way.
Something like this:
Thanks to whomever's car this is on HT
Old Apr 4, 2011 | 10:11 AM
spoon93's Avatar
Ok perfect thank you guys!!!
Old Apr 4, 2011 | 12:21 PM
efjones9's Avatar
as soon as u said u had a log mani i was like yup thats the prob lol. the ef's dont have much room up front for those, log mani's are better in 92+
Old Apr 4, 2011 | 01:46 PM
spoon93's Avatar
Wat u mean by that? Those mannis are small I'd see if it wer a ramhorn
Old Apr 4, 2011 | 08:42 PM
efjones9's Avatar
because of the position that most log mani's have the wastegate. most of the waste gates that ive seen are higher than the valve cover
Old Apr 5, 2011 | 04:17 AM
Turbo-LS's Avatar
Get an Elbow and a tial WG, those delta gates arent very good, they tend to creep
Old Apr 5, 2011 | 06:27 AM
spoon93's Avatar
Ok cool thanks by chance do u know a place tht sells the elbow or do I have to have one custom made
Old Apr 5, 2011 | 08:50 AM
Turbo-LS's Avatar
Spoolin makes one, im sure other places do too.
Old Apr 26, 2011 | 09:07 AM
99SiStyle's Avatar
Anyone know what kind of manifold that is in the picture? Looks to have really good clearance.
2004es2
Feb 27, 2009 12:51 PM
allanonjj
23
Jun 2, 2005 07:21 AM
VtecAdil
Oct 14, 2004 10:44 AM
flarinpnoi
Apr 28, 2004 09:41 AM
Muckman
Feb 22, 2004 08:13 PM
