Turbo d16z6
Old May 18, 2014 | 09:42 PM
Kid cruz's Avatar
Default Turbo d16z6
Hi I have a 93 eg civic coupe and I wanted to turbo it but I didn't know which and where to get a turbo. I don't wana spend more than 1000$ but I do want to hit 250hp.
Old May 18, 2014 | 09:51 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Turbo d16z6
Not going to happen in your budget. D series motors can't get past 200 without forged internals, and the absolute bare minimum to do a functional, reliable DIY turbo setup is $1500. Either lower your expectations a little bit, and raise your budget a little bit, or keep your expectations, and raise your budget a lot.
Old May 18, 2014 | 11:21 PM
wantboost's Avatar
Who is Mr Robot?
220 is the safe limit for stock d series internals on pump gas. the rods are super thin.
1000 dollars won't get you anywhere. that would cover the cost of a chipped ecu, tuning software (s300, Neptune, crime, etc), a wideband, bigger injectors, bigger fuel pump, and a stronger clutch.
you're looking at another 2000-2500 easy for a quality "bolt on" turbo kit using all quality, proven parts.
you could probably do a junkyard setup with a dsm t25 or a dsm 14b/16g with an hx mani and adapter plate.
or a 60 trim t3 off of an svo mustang or thunderbird with a generic cast eBay manifold, dsm 450 injectors, resistor box, used walbro 255, the free version of crome, 1 step colder spark plugs, used wideband o2 system (mandatory imo) and you need at minimum and in addition to the wideband a boost gauge and an oil pressure gauge.
depending on mileage it would be a good idea to get a new cap and rotor for the distributor as well as new plug wires,
a 3bar map sensor if you run more than 10-11psi as that's all the stock one will read, oil feed line and return line kit, someone to weld the return fitting to the oil pan, a 2.5" downpipe and exhaust (3" would be better but it costs more), a generic eBay intercooler and piping kit, generic bov (name brand would be better), generic wastegate (again name brand
TiAL, Turbosmart, Turbonetics, etc is better) or stay with the internal wg on the t3 60 trim and block off the wg port on the manifold. You also need some type of boost controller since IIRC the 60 t3 had a low pressure wastegate actuator. a quality manual unit would be fine.
you still need an upgraded clutch... buy a new one, the eBay special clutches are cheap and would work fine for you. ARP headstuds are a given as d series are notorious for head lifting under boost, you'd need a new OEM hg as well.
That's more than 1,000 but still under 2,500.. Probably around 1750-2200 if you know where to look for parts and find deals. however that doesn't cover the labor cost of install (if you doubt you can install it properly then go to a reputable shop and let the pros do it), fabricating the downpipe (you can easily find a generic downpipe on eBay that fits the ford 5 bolt turbine outlet and the generic cast manifold)and the exhaust.. people offer piping kits but they still have to be fitted and welded, however you can probably find a cheap Chinese special 2.5" exhaust on eBay.
it still needs to be tuned, you cannot drive the car around on a basemap. figure at least 400-500 for dyno tuning.
how many miles on the motor? are you sure the motor is healthy enough for forced induction? you need to do a compression test with the motor hot at least, doing a leakdown test at the same time would be a good idea..
if your compression numbers are low (below 160) and have more than a 10% difference across all 4 cylinders then it's not a good idea to boost that motor... it would be nothing more than s ticking time bomb.
You've gotta play to pay and modifying cars isn't cheap. do it right or don't do it at all.
cheap
fast
reliable
pick two because that's what your build will be.
I strongly suggest you read the forced induction FAQs at the top of this forum numerous times so you have an understanding of what all is needed to turbocharge a Honda and how to do it properly
Old May 19, 2014 | 03:59 AM
grumblemarc's Avatar
The Grumpiest
Not happening.
Old May 19, 2014 | 04:48 AM
Kid cruz's Avatar
As far as money wise I don't care. I will go higher but I don't want to spend over 1500 on just the turbo.
Old May 19, 2014 | 06:57 AM
The Grumpiest
Make up your mind. Don't want to spend more than a grand and now money isn't an option. This isn't a cheap hobby.
Advice: Go read all teh FAQs and build threads you can get your hands on.
Old May 19, 2014 | 07:46 AM
Kid cruz's Avatar
Where could I buy a decent turbo.
Old May 19, 2014 | 07:56 AM
frost_white_ej1's Avatar
C'mon guys go easy on the guy! Let clarify this a bit do you mean 1000 to 1500 just turbo itself? or 1500 on the whole setup? If the whole setup it not happening period! If turbo alone for that price range pm TheShodan he will get you square away.
Old May 19, 2014 | 08:19 AM
boostjunkie757's Avatar
somebody get this kid a glass of water..
ima throw it in his face to wake him up cause this dudes ******* dreaming..
Old May 19, 2014 | 08:22 AM
purgat0ry's Avatar
You're in the wrong hobby then.
Old May 19, 2014 | 08:52 AM
Kid cruz's Avatar
I'm not saying I'm on a budget of just 1500$ I'm saying I don't want to spend more than 1500$ on just the turbo!!!! Over all I will spend the 3000$
Old May 19, 2014 | 08:53 AM
Kid cruz's Avatar
Thank you!
Old May 19, 2014 | 09:32 AM
The Grumpiest
Thank you!
He didn't really help you.
You still need to provide more information. Solid budget. So far it's gone from one grand to three. Horsepower goal. What car will be used for.
Now get to reading. For this topic having someone hand you the information is not helping you.
Old May 19, 2014 | 09:42 AM
3000$ gets you the kit maybe..
not installed. not tuned. we are talking fmu/missing link which will net you maybe 50+ hp at the wheels...and if you dont spend the $ on fuel management/injectors you will have to replace the engine when it pops.
you cant pay, dont try to play.
Old May 19, 2014 | 10:00 AM
92_civic_eg's Avatar
yall r trippin, if he does the work himself 250hp with 3g's is easyy, build it with forged rods & vitara pistons, or put it around 200hp and save a lot of work & $$ to buy more quality parts now and plan a motor build and up the boost later on down the road n shoot for 300hp, anyways OP check out the FAQ and see everything you need, be pacient when accumilating parts n make sure anything thats used is good conditiion
Old May 19, 2014 | 10:08 AM
hondatech8798's Avatar
Lol 3G for a starter kit..
I guess I was very lucky on my first turbo'd honda in which case I'd bet the most expensive part I bought was injectors lol and that was 200 bucks for some rc's, I had a stock b18b motor and trans made a t3 top mount got a cheap turbosmart gate and a used greddy bov..
I found a good used t3 super 60 rocked that thing on 10-15 psi for almost 6 years on a street tuned using chrome, oh and driving it year round here in canada on 90-91 octane fuel
Lol
I bet I wasn't into it for over 800 bucks all sad and done!
Most fun setup I've had in my car never did anything to it just pounded it and it kept on going lol
Old May 19, 2014 | 10:27 AM
Yeah the 3g for a kit is a little off goautoworks street kit is price at 2k very decent kit http://www.go-autoworks-store.com/gocotuki.html
Old May 19, 2014 | 10:39 AM
****, revhard kits 10 years ago were about 2700..
inflation adjustment included in my prior statement. also, yes, you can find **** cheaper online, but youre not saying what type of condition et cetera...and cheap turbo kits on ebay are just that. theyre ******* **** you shouldnt bother buying to begin with.
im done. you ignorant ***** can blow yourselves and your motors while youre at it.
Old May 19, 2014 | 10:54 AM
Wow dude chill out, it's cheaper to piece together a kit getting some things used (and as i said before make sure its in good condition whatever it may be) and what new things you can afford, that's budgeting, not just buy a high quality brand new complete kit, personaly I would never do that anyway even if I could afford it and who ever said anything about an eBay kit?? I don't even think op had that in the back of his mind.. But thanks bro for being done cuz you were no help anyway
Old May 19, 2014 | 11:07 AM
The Grumpiest
It may be cheaper, but you stand a greater chance of mismatching components and spending more money getting it right. If you're buying used then you run a greater risk of getting parts with dubious history. I too went this route but the hassle and wait was almost not worth it. I almost wound up selling parts halfway through collecting. And to be frank, people that piece together bargain basement junkyard setups wind up looking like **** and they don't perform all that well (take offense if it pertains to you).
Can the OP replicate sub-$1k builds? Probably not. I'll put money that he pops for an eBay kit and runs with no engine management.
Old May 19, 2014 | 11:45 AM
scottdh20's Avatar
i've done it...it can be done...
buuuuuutttttt
it will take time to peice together, some good haggling skillz, and you need to know people
stock d16 will hold 250 just fine on a good tune...220 on a d15...again on a good tune.
if you are asking basic questions you need to do waaaaayyyyyy more reading and research. my first turbo setup cost a whopping 800 or so tuned, but it took alot of patients and research to do it
Old May 19, 2014 | 12:44 PM
Well the solution for mismatched parts is research and not just buying whatever's immediately available, and then the other things like the necessity for used parts/how long you will wait/hassles of finding useful parts at a decent price and making sure it all works together I feel mostly depends on the budget, because you gotta do what you gotta do, if u have the money but are tryin to keep funds low as possible it might not be worth it to certain people but if its all you can afford then it comes down to how bad u want it.. But yes used parts can be a risk depending on what it is and who it's from
OP just dont forget research definitely plays a HUGE part in it because as grumblemarc stated before it will just end up more expensive if its not done correctly or without proper parts/equipment, and whatever you do, don't buy an eBay kit or it will be a disaster, those kits aren't complete either..
imbest123
Nov 21, 2015 02:29 PM
hondaguyexsi
Oct 14, 2005 03:05 PM
streetlvlhatch
Jun 20, 2005 02:49 PM
EJ1 wilcox
Apr 22, 2004 08:02 AM
del_sol
Oct 26, 2002 02:32 PM
