Turbo D16A1 tuning questions.
Well I got the turbo on my 85 Si W/D16A1, went to the track and did a best of 14.5@98mph on 5.5-6psi boost on my street tires. I have known people that have had similar times on the SOHC D16's in the 2G crx's and feel that I should be a bit faster, after reading a little bit in the maximum boost book I have, I have discovered that long duration high lift cams are bad for turbo engines (I am running the JDM CRX ZC cams 135hp version of the ZC's) it supposedly causes a lot of reversion. These cams are just that compared to the original cams, but I think that by advancing the exhaust cam and retarding the Intake cam may cure some of the reversion and produce more power......does anyone have any ideas?
Cj
My setup
http://65.57.232.177/modules.php?nam...iewtopic&t=890
Cj
My setup
Re: Turbo D16A1 tuning questions. (cjmech)
You're able to run stock ignition timing with up to 12 psi of boost?
You should get that thing on a wideband dyno and tune the fuel. There is probably a lot of power to be had there.
The JDM ZC cams are agressive, but I doubt that they are any more agressive than any of the VTEC lobes on the B16A/B18C engines. I had cam gears on my supercharged B16A2 and found the best settings to be at 0,0. A lot of people find that 0,0 works very well (if not best) for stock cams.
Sonny
[Modified by Sonny, 12:00 PM 9/5/2002]
Sonny
Re: Turbo D16A1 tuning questions. (Sonny)
I am currently working on a wideband sensor setup so that I can tune it as much as possable without going to a independant system.
http://techedge.com.au/vehicle/wbo2/default.htm
This system is sooo much better than the piece of junk autometer gauge.
I had my cams set at 3deg advanced on the intake side and retarded 2 deg on the exhaust and was running 14.6-.7 then when I turned them to zero I ran the 14.5. My teg cams created alot of low and mid range torque when I had it all motor, scince I get boost at 2k I think these may be better to use, the ZC cams I am running dont really start to breathe till around 4k and from then on its pretty sweet.
I just have to experiment with it I guess.
Also on going to 12psi with no timing problems once for a brief second or 2, I cant really say but I did not pull a code and it pulled hella hard. I had it at 10 psi a few times and held it for a short run (road test) and had no problems but I wouldnt want to leave it for eveyday driving.
Cj
Cj
hey man hows that tech edge wb? i was just checking out their site and am looking into one of these. how do u like it? where do u plumb in the o2 sensor that goes with the unit?
nice run on ur rex!
peace
[Modified by KiddEng, 11:07 AM 9/6/2002]
nice run on ur rex!
peace
Re: Turbo D16A1 tuning questions. (KiddEng)
I havent completed the kit yet, I am still waiting on the rest of the parts to come in. I had my downpipe custom built and had 2 02 sensor bungs installed in it so I can run a universal 1 wire to the ECU and the wideband seperate scince the ECU doesnt know how to read a wideband sensor.
Cj
Cj
cool man...well let us know how it goes when u get it assembled...if its a go..then imma have to order one myself. pre-assembled of course as im not good with circutry (sp).
peace!
peace!
CimorelliCRX
07-27-2002 02:04 PM
