turbo cams
Old Jun 10, 2002 | 07:41 AM
Dorikamu's Avatar
Default turbo cams
From my understanding.. high lift cams for a NA car has the potential to produce more power in the high end, and that's why NA car with higher compression ratio can benefit from it.
can someone explain how does a turbo car benefit from turbo cams? how does turbo cam works better than stock besides the fact that it's stronger?
Thanks!!
Old Jun 10, 2002 | 08:14 AM
CovertFI's Avatar
Default Re: turbo cams (chusai)
i think it mainly has something to do with the timing. they call it over lap. dont know what it means but they say you dont want over lap with a turbo cam.
Old Jun 10, 2002 | 09:42 AM
B-series Assassin's Avatar
Default Re: turbo cams (CovertFI)
Who said this?
Old Jun 10, 2002 | 10:42 AM
CovertFI's Avatar
Default Re: turbo cams (B-series Assassin)
on this forum
Old Jun 10, 2002 | 10:55 AM
inspyral's Avatar
Overlap is when the intake and exhaust valves are open at the same time. N/A cams have more overlap, and it promotes good flow in those applications, but you don't want overlap in a boost application since the boost will essentially blow right thru the combustion chamber and out the engine.
Old Jun 10, 2002 | 11:10 AM
DC2R714's Avatar
Default Re: turbo cams (inspyral)
Inspyral has got it, thats why many people get adjustable cam gears to dial out the cam overlap. From what my tuner told me you can gain around 20-30hp from doing this.
Old Jun 10, 2002 | 11:11 AM
CovertFI's Avatar
Default Re: turbo cams (DC2R714)
but if you dial it out you change your timing. right?
Old Jun 10, 2002 | 11:35 AM
intekragsr's Avatar
dont turbo cams increase duration? Correct me if Im wrong, but it lets the intake valve stay open longer so more air can be forced in? This was my understanding but dont take my word.
Old Jun 10, 2002 | 12:53 PM
turbo craig's Avatar
Default Re: turbo cams (intekragsr)
i thought that turbo cams increased lift. hmm im prolly wrong but i thought i read somewhere too much duration was bad i forgot why it said that because it was a long time ago but still im prolly wrong still a n00b
Old Jun 10, 2002 | 12:58 PM
HXMan's Avatar
I am sure turbo cams increase duration, decrease overlap, and maybe increase lift a little.
Old Jun 10, 2002 | 01:21 PM
CovertFI's Avatar
Default Re: turbo cams (turbo craig)
Not and expert but too much duration means the valve is open longer, well that cant be good when a piston is moving up in the combustion chamber. piston hitting valve not good!!
Old Jun 10, 2002 | 01:27 PM
wait so i was right? right?
Old Jun 10, 2002 | 01:31 PM
The_Head's Avatar
So is this how it goes?
Duration = time when both (or all 4) valves closed
Overlap = time when both valves are open
if thats it then a turbo cam would minimize the valve overlap, so the pressurized mixture wouldnt go out the exhaust port...
Old Jun 10, 2002 | 01:40 PM
CovertFI's Avatar
if i am right you are right. you follow me!!
*again i am not an expert
Old Jun 10, 2002 | 01:41 PM
CovertFI's Avatar
Default Re: turbo cams (xThexHeadx)
duration= how long the valve is open. other than that your are right.
Old Jun 10, 2002 | 02:27 PM
tonydatyga's Avatar
4 stroke cycle... no valve is open during the compression stroke... even w/ an aggressive, counterproductive amount of duration. pistons will be domed or have cuts so that open valves still have clearance w/ tdc piston. of course this differs w/ every application (mitsu 1.8 na engine have flat piston heads for example). it is possible to do everything an engine is not supposed to do so don't try to apply dumbass situations
Old Jun 10, 2002 | 02:30 PM
93LSivic's Avatar
From what I understand optimal turbo cams will:
Have low duration and high lift.
Have minimal overlap.
Wont idle too good.
Require springs and retainers.
Only really benefit if head is P&P.
Produce good amount of horsepower.
Sound bad ***.
Old Jun 10, 2002 | 04:35 PM
CovertFI's Avatar
Default Re: turbo cams (tonydatyga)
not if you are reving high and your valves are close to floating or are already floating.
Old Jun 12, 2002 | 02:23 PM
tonydatyga's Avatar
a good example of a mildly dumbass situation. Try having a valvetrain that can keep up w/ the current system before looking into mad tizzite turbo cams.
Old Jun 12, 2002 | 04:51 PM
boosted3g's Avatar
I have tried nearly every cam on the market for my Ls and all seem to be far better than stock its just where you want the power. Right now i have the Crower 62404 cams in and they make good power its jsut way high in the power band. I can make peak power at over 9K. I am trying to get ahold of the 62402T cams but Crower is being cooperative and giving me a release of when they will have them. They say they are out of cores but they wont tell me if anyone else would have them, like Race Engineering. Basically a good turbo cam will just have a retarded intake cam. For an in depth article on turbo and cams check out the August 2001 article on the 2.3 SVO mustang in Mustangs and Fast Fords Magazine. Its a very good article (probably a first for that magazine)
Old Jun 13, 2002 | 06:05 PM
tonydatyga's Avatar
Default Re: turbo cams (boosted3g)
And where would one go to obtain a copy of said publication?
Spawne32
Oct 22, 2010 03:11 PM
rice is nice
Nov 30, 2004 06:47 PM
4ghatch
Feb 2, 2003 09:36 PM
CimorelliCRX
Jul 27, 2002 02:04 PM
