D series turbo question
Old Feb 26, 2006 | 06:15 PM
MBlake55's Avatar
Default D series turbo question
Do i need a sandwich adapter for my dseries turbo setup, does that mean that i dont have to drill and tap my oil pan? or wat exactly is that? thanx
Old Feb 26, 2006 | 06:19 PM
Soccerking3000's Avatar
Default Re: D series turbo question (MBlake55)
no the sandwich adapter is for the oil feed while the tapping of the oil pan is for the oil return. I suggest you read a little more before boosting, but thats just my opinion...
Old Feb 27, 2006 | 06:09 AM
MBlake55's Avatar
Default Re: D series turbo question (Soccerking3000)
thanks, so basically i need that sandwich adapter regardless if i drill and tap the oil pan?
Old Feb 27, 2006 | 06:14 AM
VTcivicHB's Avatar
No, you don't need a sandwich adapter. The sandwich adapter is for your oil feed and when you drill and tap your oil pan its for the oil return (gravity feed). instead of using a sandwich adapter, just tap off your Oil Pressure Sensor, its really not as hard as you would think.
Old Feb 27, 2006 | 10:18 AM
Default Re: (VTcivicHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTcivicHB &raquo;</TD></TR><TR><TD CLASS="quote">No, you don't need a sandwich adapter. The sandwich adapter is for your oil feed and when you drill and tap your oil pan its for the oil return (gravity feed). instead of using a sandwich adapter, just tap off your Oil Pressure Sensor, its really not as hard as you would think.</TD></TR></TABLE>
the only problem is the fitting can snap off in the block and then **** hits the fan. If you get the fitting for the oil pressure sender i would recommend that you do a remote distribution block thats mounted to the firewall.
Or you could do what i did and have the oil pressure sender removed and put a straight fitting and have an oil run straight to the turbo, completely removing the oil pressure sender (its useless anyway)
Dual Cam Killer
Dec 12, 2009 06:37 AM
D16y8_619
Sep 8, 2006 09:05 PM
swatteamtimmah
May 7, 2006 04:19 PM
moesrex
Apr 3, 2006 07:35 PM
TrueUntilDeath.com
Feb 12, 2005 10:13 PM
