obd0-1 turbo ?s
obd0-1 turbo ?s
whats up H T ? ive got a 90 si ef with a odb0 b16a. curently installing greddy 18g turbo i am converting to obd1 i have the conversion harness, ecu, hondata s200, obd1 dizzy and dsm blue top injectors. ive got 3 questions.
can i use the dsm injectors with my stock clips and resister box?
do i need to change my stock map sensor or modify?
aslo should i use a dedicated vacuum source for the internal wastegate or will using a vacuum block/manifold work fine? thanks in advance any help appreciated
Re: obd0-1 turbo ?s
injector clips will work.. stock map sensor is fine up to 11psi of boost. the wastegate should be hooked up to the turbo. tap the turbo housing or the intercooler pipe down by the turbo
Re: obd0-1 turbo ?s
map cool i will be at 6-8 psi for now
id rather not drill my housing i can tap piping before intercooler or after ic?
Re: obd0-1 turbo ?s
Before intercooler. tap right after turbo housing.
Re: obd0-1 turbo ?s
No. You most likely will be fine with the stock black box on the back with using the greddy kit on 8psi. but if you run any kind of catch can setup get the 2 fittings for the back of the block. and just run them to a catch can. that gives you the best ventilation for crank case pressure.
Hondadaturbo
Engine Management and Tuning
04-16-2010 11:26 AM
