map advice
Old Dec 13, 2005 | 08:04 PM
Got_soy's Avatar
Default map advice
I plotted some points on a 14b compressor map for my d16a6, Becasuse I have no idea
of what rpm it would start to build psi I graphed all psi at all rpm. Does this look right at
all? I've seen other maps and I was wondering if I'm going in the right direction or if I
should stop and ask. heres the map
http://my.prostreetonline.com/...=3635
Old Dec 13, 2005 | 09:20 PM
b16hybridsol's Avatar
Default Re: map advice (Got_soy)
you lost me on your logic for putting the points where you have them. You use RPM, VE, PSIa, CFM, CID, and a few constants to figure out where your plots go. Should look something like this when you are done, although this is just for 2 boost levels (street/ strip) and 2 rpms (about where full boost is achieved and redline)
look around google there are hundreds of write ups on this, its fairly complex. g-luck
Old Dec 13, 2005 | 09:34 PM
Got_soy's Avatar
Default Re: map advice (b16hybridsol)
This is were i got the logic. http://www.stealth316.com/2-3s-compflowmaps.htm
Brandenvtec719
Apr 11, 2018 06:58 PM
Txdragon
Engine Management and Tuning
Mar 8, 2017 05:57 PM
rorik
Jan 23, 2006 06:27 PM
dsadas89das78934
Jun 6, 2004 06:45 PM
