looking for a good sohc 3 bar map bin (uber)
Old Jun 10, 2005 | 08:31 PM
alexsracing's Avatar
Default looking for a good sohc 3 bar map bin (uber)
would really want beerbongs map converted for the 3bar mapsensor
uberdata bin
Old Jun 11, 2005 | 08:17 AM
Default Re: looking for a good sohc 3 bar map bin (alexsracing)
bump
Old Jun 11, 2005 | 05:12 PM
up
Old Jun 11, 2005 | 05:35 PM
Bailhatch's Avatar
Default Re: (alexsracing)
LOL classic.
Old Jun 11, 2005 | 07:28 PM
evosol's Avatar
Default Re: (Bailhatch)
i got an idea. Take (insert desired map), burn it onto a chip, plug it into ECU, add wideband, then tweek to desire.
Old Jun 11, 2005 | 07:34 PM
I checked the 3 bar option but the values changed for vac and boost on the top,
having trouble idleing, and once it sees 5 psi it cuts.
Old Jun 11, 2005 | 07:44 PM
non-VTEC's Avatar
i dont have a 3bar so im not to sure but i do belive some of the guys have to change the "fuel cut" number in order to get the 3bar map sensor to work correctly.......
look in the boost tab and the default number is 24.....you need to lower it i think but im not sure what number you need.........search the uber forums for some anwers.
Old Jun 11, 2005 | 09:19 PM
Bailhatch's Avatar
Default Re: (non-VTEC)
fuel cut @ 7 works usually, unless you wont tune it and insist on just copying a random map off the internet. then you are fucked
Old Jun 12, 2005 | 09:16 AM
i have been using the map for 6 months perfectly , just upgrading to a 3bar map sensor and having problems.
simple as that.
Old Jun 12, 2005 | 09:40 AM
rioninja's Avatar
Do you even have a wideband?
Not trying to be rude, but it doesnt sound like it.
Old Jun 12, 2005 | 02:43 PM
i have the plx m-500
but im don't need all the comments, just a converted map for 3bar map sensor up to the 11 psi mark, I can do the rest once its there.
Old Jun 12, 2005 | 03:25 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexsracing &raquo;</TD></TR><TR><TD CLASS="quote">I can do the rest once its there.</TD></TR></TABLE>
So if you can tune it no problem, why not just make a 3 bar base map and tune it?
Old Jun 13, 2005 | 08:49 AM
just trying to make it easier if someone else had a 3bar base
Old Jun 13, 2005 | 09:35 AM
MiKeAhOwSkI's Avatar
you have PM!
Old Nov 22, 2005 | 12:52 PM
O16581724 5 2 5's Avatar
I'm looking for the same thing, i figured in 14 replies there would be something of value, but it's bullshit and not what he asked.
Old Nov 22, 2005 | 01:40 PM
blundar's Avatar
buncha lazy whiny maggots...
If you can't take the heat, get your *** out of the kitchen.
If you can't convert a 1.8 bar tune over to a 3 bar tune, step away from the laptop.
algebra 0wnz j00!
h23aAccord
Mar 25, 2017 04:53 AM
jacky4566
Engine Management and Tuning
Dec 26, 2010 11:31 PM
KRWTEK1
May 28, 2007 12:32 AM
philo
Dec 3, 2002 08:37 AM
