Tuning question.
Old Jan 28, 2003 | 06:13 AM
Speed PHreak's Avatar
Default Tuning question.
Ok, I just got my new 85# injectors installed into my setup not too long ago. I'm here having fun tuning them in with my FJO wideband, it makes it a breeze. Well this morning a good question popped into my head. I'm in NC and right now it's about 30~40 degree's, i'm tuning my setup to 12:1 AFR in this cold-*** weather. Now say when summer gets here and it 75~90 degree's out, how bad is my car going to be running rich?
I guess what i'm trying to ask is how many of you guys out there run seperate tunes for the summer/winter, or different tunes depending on the outside temp. ?
Old Jan 28, 2003 | 08:41 AM
boostaholic's Avatar
Default Re: Tuning question. (Speed PHreak)
What ecu are you running? Does it have an auto temp correction factor? With my speedpro i can set a certain level of positive or negative correction based on the intake temp charge.
Old Jan 28, 2003 | 10:02 AM
boosted hybrid's Avatar
I have seen a .3~.5 difference from winter time settings to the summer time. I like to set up and tune in the early spring so i get an average temperature and that usually keeps the mixture fairly consistent.
[Modified by boosted hybrid, 2:02 PM 1/28/2003]
Old Jan 28, 2003 | 01:03 PM
Default Re: Tuning question. (boostaholic)
I'm running a Zdyne SECU. I'm sure it has a certian amount of temperature correction within the N/A portion just like all ECU's do, but i'm not sure about the boosted section of the fuel curving.
92frostwhtdb2
Aug 21, 2011 03:07 PM
Spawne32
Jun 5, 2011 07:20 AM
Chub
Nov 30, 2009 07:21 PM
99blackdc2
Aug 30, 2006 04:08 AM
99TurboFerio
Apr 7, 2005 04:37 PM
