tuning low compression
Old Sep 23, 2006 | 07:42 PM
jarvis199's Avatar
Default tuning low compression
setup:
-75mm vitara pistons (8.5:1 in d16z6)
-tuner toys rods w/ arp bolts
-arp headstuds
-fresh gaskets, seals, etc.
turbo:
t3 .48/60
450cc dsm black tops
plxm300 wideband
bkr7e plugs
homemade manifold
i guess thats all that matters, so now on to the questions...
Im tuning it at the moment, and i was wondering how many degrees do you pro tuners advance the timing in the vac portion to pick the power back up due to the lower compression??? what kind of buffer zone does this lower compression give me, as far as preventing detonation i mean??? say im at 15psi im at 20.50 degrees total timing, and at 20 psi im at 16 degrees, does that sound like a lot for a 75mm bore 8.5:1 motor??? i know i should be tuning timing on a dyno, but i just dont have access to one around here for a while, so im trying to get it safe without being too safe, if that means anything to you...
the afr is pretty solid at 11.5:1, now im just trying toget my timing right...
right now im at 19psi and 16 degrees and the plugs are showing up with a TAD bit of white specs on the porcelin, no cracked anything YET, any clues, hints, help, advice, would be sweet...
thanks
Modified by jarvis199 at 12:03 PM 11/1/2006
Old Sep 24, 2006 | 08:49 AM
jarvis199's Avatar
Default Re: tuning low compression (jarvis199)
bump...
Old Sep 24, 2006 | 08:57 AM
AbitAvenger's Avatar
bump... i have a stock z6 with dsm 450's i could post my map if ya want... its pretty conservative
what are you using to tune btw?
Old Sep 24, 2006 | 09:06 AM
SOHC_MShue's Avatar
my advice is to go somewhere with a dyno if at all possible
Old Sep 24, 2006 | 02:46 PM
jarvis199's Avatar
Default Re: tuning low compression (SOHC_MShue)
figured the whole dyno thing was coming, but still, i know i need to dyno, i was wanting to get it close on the street...
Old Nov 1, 2006 | 11:02 AM
jarvis199's Avatar
bump
the_yblegal
Engine Management and Tuning
Jun 2, 2014 04:50 PM
EnzoSpeed
Nov 3, 2005 02:08 PM
S@nt0s
36
Oct 14, 2005 07:02 PM
1.8T_EG
Apr 29, 2003 04:46 PM
