windage tray?
Old Oct 30, 2006 | 05:36 AM
VtecnTurbo's Avatar
Default windage tray?
whats the function of the windage tray? do i need it in a gsr??
Modified by VtecnTurbo at 6:49 AM 10/30/2006
Old Oct 30, 2006 | 08:34 AM
VtecnTurbo's Avatar
Default Re: windage tray? (VtecnTurbo)
Nobodies knows the purpose of an oil windage tray?!?!
Old Oct 30, 2006 | 09:46 AM
beepy's Avatar
A windage tray helps keep oil down in the pan and off the crankshaft. Smokey Yunick talks about it in depth in Power Secrets, which is a book everyone should own. Basically oil on the crank is unavoidable (without a dry sump oiling system) but a windage tray helps keep it more consistant, leading to reduced parasitic loss and more consistant engine balancing.
A good windage tray should be matched with a properly fitted crankshaft scraper to really get the full benefit, though. Most people don't bother.
Old Oct 30, 2006 | 01:18 PM
VtecnTurbo's Avatar
Default Re: windage tray? (beepy)
thanks
Old Oct 30, 2006 | 02:12 PM
quicksilver1689's Avatar
i ♥ snails
HEy where can I get this book power secrets? Is this the same smokey that the old one talks about or endyn?
Old Nov 1, 2006 | 11:06 AM
Alfa Turbo's Avatar
"but a windage tray helps keep it more consistant, leading to reduced parasitic loss and more consistant engine balancing."
Sorry to disagree... a windage tray helps prevent air from being whipped into the oil by the rotation of the crank. Parasitic losses from oil are very small and balance has nothing to do with it. It is an oiling issue, air in the oil can cause bearing failure which can ruin your weekend.
kevin j
Apr 3, 2014 04:39 PM
jdm_Jim
Feb 10, 2012 07:08 AM
lurkin' eg
Feb 12, 2008 05:07 PM
WalkerGSR1
Jan 4, 2007 07:31 PM
PaChiLa Leader
Sep 12, 2005 10:58 PM
