Tried searching? Is there a link for injector size/hp ratio?
I was looking for a link to see how much hp 450 , 550 ...etc injectors can handle.
thanks
thanks
Re: Tried searching? Is there a link for injector size/hp ratio? (HT Chaplin)
wassup dood,
Check out http://www.rceng.com/technical.htm they have calculations that help you figure that stuff out.
For BSFC use .50 and .65 as a high and low, and also use 80-90% duty cycles for the same thing. By that I mean calculate the injectors sizes twice. First use 0.5 BSFC and 90% which will tell you the MAX HP you can get but you'll be pushing the limits, and calculate it again but use 0.65 BSFC and 80% which gives you a lower HP number that is a little more conservative.
Re: Tried searching? Is there a link for injector size/hp ratio? (dustin)
what about a nitrous setup? would you just go according to N/A power since the nitrous setup supplies it's own fuel?
Re: Tried searching? Is there a link for injector size/hp ratio? (whatVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatVTEC »</TD></TR><TR><TD CLASS="quote">what about a nitrous setup? would you just go according to N/A power since the nitrous setup supplies it's own fuel?</TD></TR></TABLE>
anyone?
anyone?
