how much Hp do 680cc injector support
Old Feb 19, 2008 | 10:54 PM
rookshot06's Avatar
Default how much Hp do 680cc injector support
hi can someone please let me know how much Hp will 680cc injectors support?
Old Feb 19, 2008 | 11:45 PM
carrnut21's Avatar
Default Re: how much Hp do 680cc injector support (rookshot06)
http://www.phearable.net/shopp....html
looks like 120 hp per injector at 90% duty cycle.
Old Feb 20, 2008 | 04:02 AM
markaria's Avatar
Default Re: how much Hp do 680cc injector support (carrnut21)
Maybe 120 crank hp but I don't believe 120whp per cylinder at 43.5psi fuel pressure...
I would think that they would be at their max by 400whp.
Old Feb 20, 2008 | 05:53 AM
Mase's Avatar
Default Re: how much Hp do 680cc injector support (markaria)
really depends a lot on your setup. how efficient/turbo range/fuel pressure.
usually you can get 450 whp out of them.
Old Feb 20, 2008 | 11:54 AM
Schister66's Avatar
Man U FTW
The general rule of thumb is 6cc per whp
680cc x 4cyl = 2720cc
2720 / 6cc (per whp) = 453 whp
The above equation works for gasoline and will keep the injector duty cycle in the 75-85% range. If you use E85, a conversion factor of 1.3 needs to be applied. Hope this helps
Old Feb 20, 2008 | 04:51 PM
rookshot06's Avatar
Default Re: (Schister66)
thanks for all the info..
Old Feb 23, 2008 | 04:10 AM
SJersey's Avatar
Here are a few good calculators to help figure out how much HP the injectors can handle: http://injector-rehab.com/imcw/
or help you select the correct injector size based on the horse power you wish to reach: http://injector-rehab.com/issg/
Hope that helps
Old Feb 26, 2008 | 04:33 PM
rookshot06's Avatar
Default Re: (SJersey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJersey &raquo;</TD></TR><TR><TD CLASS="quote">Here are a few good calculators to help figure out how much HP the injectors can handle: http://injector-rehab.com/imcw/
Hope that helps</TD></TR></TABLE>
thanks
h22slohatch
Jan 18, 2018 08:52 AM
Nikademo
Apr 22, 2010 01:46 PM
RogueWorks
Mar 23, 2008 11:20 AM
Odiedogcx
Nov 13, 2005 12:18 PM
S2KP
Jul 2, 2004 10:28 PM
