Treadstone Intercooler
Old Jan 11, 2016 | 09:09 PM
  #26
96ekb20's Avatar
Default Re: Treadstone Intercooler
so im getting ready to order my thread tone intercooler for my b20b 450whp build it will be on e85 and im wondering which intercooler from them i should get im plaining on using the intercoolers with the center inlet and outlet instead of on the bottom. im looking at the 500hp tr8c or the tr10c lmk what you guess think.
Old Jan 11, 2016 | 09:14 PM
  #27
96ekb20's Avatar
also would you run the intercooler piping kit that has it go next to the transmission or through the side of the frame horn where you have to cut the whole. im plaining on a cx racing kit and buying a greddy bov
Old Jan 12, 2016 | 11:28 PM
  #28
extremeracer's Avatar
Originally Posted by TheShodan
Those cores aren't great to begin with. So, with that said, if no other choice, go for the bigger one.
Hi, we planning on buying a large Treadstone core for our Drag Car (72mm Turbo, 95 lb/min). Does your comment relate to the specific cores the OP was mentioning or the Treadstone range in general.
The core I'm looking at is the 18 x 12.5 x 4.5 (1000Hp)
Old Jan 13, 2016 | 03:30 AM
  #29
TheShodan's Avatar
Moderator
Treadsrone's fin setup in general. But if you already got it, try it, it may be just enough for under 1000hp.
Old Jan 13, 2016 | 12:37 PM
  #30
96ekb20's Avatar
theshodan the core sizes im looking at they rate at 500 and 666hp 7.8x22x3.5 and 10.5x22x4 which do you think would be best from those 2? my set up wont go over 500whp and i dont plain to grow for a year or two so is the bigger one be best as there not that great of a cooler ? and isnt a center in and out the best route to go as stated earlier it allows air to across the cooler more effectively.
Old Jan 13, 2016 | 01:53 PM
  #31
TheShodan's Avatar
Moderator
Again, if you must use a Treadstone, I'd be safe and use the larger one. (which is about good to 570whp at its maximum, anyway.) .
Old Jan 13, 2016 | 03:09 PM
  #32
96ekb20's Avatar
ok well that fits my needs perfectly
Old Jan 13, 2016 | 03:16 PM
  #33
LightningTeg's Avatar
Community Builder
I've got the TR10 which is the one rated for 666hp. Never noticed any high temps except at the track heat soaking the IAT sensor.
I had the TR8 on my 300whp build anticipating I was going to go for more. But they are constructed well.
Old Jan 14, 2016 | 04:58 PM
  #34
96ekb20's Avatar
thank you both for your input. ill be getting the tr10c which has the center in and out tanks as stated earlyer in the post.
97CWITR
Dec 1, 2005 03:48 PM
ZhaGg
Sep 5, 2004 08:14 PM
ATS*Mark
May 15, 2004 04:37 PM
metal-x
Feb 28, 2004 04:50 PM
