Catch Can for B20/Vtec Turbo
Old Jan 14, 2016 | 05:42 PM
Todallybuilt's Avatar
Default Catch Can for B20/Vtec Turbo
What is the best way to install a catch can for my B20/Vtec turbo? I'm confused from what I've researched some folks said that is best to have routed to the back of the block and others to the valve cover. Can somebody clear this up with a diagram or pics? Thanks
Old Jan 14, 2016 | 06:06 PM
turbohatch96y7's Avatar
Wow
This has been covered to the death
Look up official catch can thread
Itll pop up
Old Jan 14, 2016 | 06:29 PM
2kdrift's Avatar
Default Re: Catch Can for B20/Vtec Turbo
Either will work, back of the block has a tendency to suck up more oil then the valve cover.
at the end of the day its just preference really
Old Jan 14, 2016 | 11:23 PM
FeelTheBass's Avatar
The back of the block would be the easiest, unless you are down to weld some fittings to your valve cover.
I'm running an OBD2 b18b1 (no black box), which is the same as the b20. These are the fittings I used:
Acura Honda Catch Can Block Adapters Plug PCV B18 B16 B20 LS GSR SI Fittings | eBay
These are actually OEM honda fittings, forgot the part number. Just buy some good quality PCV hose, a baffled catch can, and you're good.
you're welcome
Old Jan 15, 2016 | 03:31 AM
seelback's Avatar
Originally Posted by turbohatch96y7
Wow
Itll pop up
+1 theres soo much information on here to start with.
sho_shane
25
Mar 5, 2010 09:24 AM
akandok
18
Sep 17, 2009 04:21 AM
DrGrEeNtHuMb
Jul 30, 2009 04:30 AM
showtymers619
May 1, 2004 09:21 PM
showtymers619
Apr 27, 2004 06:39 PM
