torque for oil feed line
Old Dec 23, 2004 | 10:34 AM
civickiller's Avatar
Default torque for oil feed line
ok so im putting on a turbo feed line. my question is how tight are you suppose to make the line to the turbo fitting, its regular brass fittings, the hose is small so its not like a 6an or something it would be more like 3an or maybe smaller ? is there a torque number or what ?
also is teflon sealer required, im not using teflon tape but a teflon paste
thanks
Old Dec 23, 2004 | 12:31 PM
Default Re: torque for oil feed line (civickiller)
bump
Old Dec 23, 2004 | 12:44 PM
civicross's Avatar
No sealer on AN fittings. And you don't need to make them extremely tight, just like oil drain plug tight.
Old Dec 23, 2004 | 12:49 PM
Default Re: torque for oil feed line (civicross)
what if i already put sealer on an an fitting, should i remove it or will it be ok ?
Old Dec 23, 2004 | 08:48 PM
civicross's Avatar
I would clean it off.
Old Dec 23, 2004 | 09:26 PM
IN VTEC's Avatar
I would remove the sealant too. If it hardens up on the seating angle of the AN flare, it might prevent the seating angles from sealing.
jacob4lester
Feb 16, 2010 08:36 PM
iHOPEyouCHOKE
May 27, 2006 09:24 AM
91backslash
Oct 30, 2005 10:00 AM
mattcalica
Aug 16, 2003 06:20 AM
Snafu-Si
Jul 2, 2002 07:58 AM
