Too small of an intercooler =??
What are the downsides of picking an intercooler that may be too small- the only problem is that the intake charge will not be cooled as much? If some other cooling effect is added downstream (like auxiliary meth injection) I'll be able to get by with a relatively smaller IC, correct?
Thanks
Ben
Thanks
Ben
setup is a 2L 500hp B18C, looking to go with a 6x18x3" IC...maybe smaller.
I've done a bit of investigating with the methanol injection- the Supra guys were getting intake charges around 32 F. I need the IC to keep temps down when the meth isn't on- low/unboosted conditions.
Thanks
Ben
Thanks
Ben
ive never really seen an intercooler too small but if your running high boost then a slightly bigger one might do to keep the intake temps cool but i dont think there is a huge difference...but i might be wrong
Back from the dead...here is the answer to my original question in case it helps anyone-
The intercooler, if insufficient for your power levels, will manifest
it's problem in pressure drop, not high temperature. There are two things to
consider when matching a intercooler to a setup. Flow capability, and
efficiency. From what I have seen, almost all front mount ICs for the MKIV are
pretty good in efficiency. They range from superb to very good in this regard.
Flow capability is another story. The smaller ones will start to show a pressure
drop across the core at high airflows. No amount of cooling, water/methanol
injection will cure this. Pressure drop goes up exponentially to airflow once
you start to "push too far." You could be seeing 30psi in the manifold, but it
could be 35psi at the turbo. The turbo is working harder, robbing power, just to
overcome the resistance of the intercooler. If you "hit the wall" with a small
intercooler on a large turbo, methanol/water injection won't cure the problem.
If will help with any THERMAL deficiencies, but can't do a thing for FLOW.
dnbruut
Feb 28, 2005 02:06 PM
