Intercooler I/O too small?
Old Jun 24, 2009 | 08:03 AM
purpleh22's Avatar
Default Intercooler I/O too small?
The intake and outlet on my intercooler has an inside diameter of 2 1/4 inches. GT35 outlet is only 2". the rest of the intake ducting is 2 3/4 inches with a 70 mm throttle body. This is on a built H22 running 22psi. and 500+ whp. Would there be any advantage to having 2 3/4 inlet/outlet on the intercooler. How much difference? Even though the system is pressurized it seems it would restrict flow. Any velocity issues? This is an E85 street driver.
The shop where I bought it (they're doing the work) says it doesn't really matter since they're bigger than the turbo outlet and it's a pressurized system, unlike NA.
Anyone ever try different intercoolers with different openings and other things remaining the same?
Old Jun 24, 2009 | 03:07 PM
nuclearhappines's Avatar
Default Re: Intercooler I/O too small?
Here's how my math comes out for 500hp @ 22psi:
Intake dimensions:
Cold side piping = 129.86 mm - Before the supercharger or turbocharger
Hot side piping = 83.02 mm - After the supercharger or turbocharger
Throttle Bodies = 1 x 83.02 mm
Intercooler dimensions:
Intercooler minimum inlet area = 27.0 square inches (this is the surface the air sees coming into the intercooler so your depth X your height)
Intercooler minimum volume = 843.0 cubic inches (depth * height * width)
If my math is right, that's the sizing that will give you less than 1hp loss in your intake path... anything smaller will work, but you'll be trading off top end for lag / throttle response / pressure response ...
http://www.superchargerperformance.c...alculator-v2-3
Old Jun 24, 2009 | 05:24 PM
purpleh22's Avatar
Don't know of many intercooler inlets that are that large. If the GT35 turbo outlet ID is 2" would I lose much having 2 1/4" intercooler inlet/outlet over having it be 2 3/4" from the turbo to the throttle body (70mm TB).
Old Jun 24, 2009 | 09:20 PM
purpleh22's Avatar
Intercooler has been pulled. I will get one with larger I/O if it will make a difference.
Old Jun 25, 2009 | 04:23 PM
purpleh22's Avatar
Ordered intercooler with larger I/O. Waste of money?
Old Jun 25, 2009 | 08:32 PM
MrDomino's Avatar
dyno it and let us know.
Old Jun 26, 2009 | 10:15 AM
EARLdaSQUIRREL's Avatar
official honda whore
a better core would have more of an effect at those size i/o then new inlets or outlets
ntoxicatedtigah
Jan 27, 2009 03:38 PM
jdm inc
Jul 30, 2006 12:38 AM
eg:R
Nov 30, 2005 12:36 AM
