Garret AiResearch turbo?
1 Post
I pulled a Garret AiResearch turbo off a dodge daytona and don't know the spex, but it looks about the same size as an t28 or something like that. Anyone know the spex? Stock actuated Boost, T-what? Anything? TIA
Re: Garret AiResearch turbo? (technine)
Take it apart and measure everything. If you remove the compressor housing, you'll be able to see what size the wheel is.
The a/r of the exhaust turbine is usually stamped right inside the opening. The a/r of the compressor housing is usually stamped right inside the outlet.
Sonny
Sonny
1 Post
Re: Garret AiResearch turbo? (Slow_ass_4dr)
thanks guys, and I also finaly found something on the net that has them rated at a stock 7-7.5psi wastgate setting. I'm gonna try to lengthen the rod to get it down to like 5 or 6psi for daily driving and also once I get them darn thing setup on my motor.
