Timing question
Old Apr 15, 2011 | 08:53 AM
93lsv_turbo's Avatar
Default Timing question
I want to see if I have this correct if you advance or retard timing your talking about atdc correct. So lets say to retard atdc timing you increase btdc timing. I understand the event in stock terms I'm just a lil confused when it comes to any changes. Thanks for the help
Old Apr 15, 2011 | 09:36 AM
Default Re: Timing question
Also lets say I use the 1 degree of time per pound of boost. Im running 5 pounds so I take out 5 degrees and stock honda timing is 16 atdc so that puts me at 21 degrees total. I dont think this theory would work for some thats running 20 pounds of boost because of the efficiency of our motors at higher rpms. Help me out just trying to understand.
Old Apr 15, 2011 | 09:53 AM
kyden's Avatar
a plug is never fired atdc (unless waste spark), that doesn't make any sense. everything would be btdc. you're looking at base timing as a set timing. go look at a map, there's different timing for all conditions.
Old Apr 15, 2011 | 10:25 AM
Garage 808 Hatch's Avatar
if stock is 16* BTDC and you retard it 5*, you would be at 11* BTDC. when you retard the timing, it happens later, which makes it happen closer to TDC
But 16* BTDC is only at idle. As RPM and load go up, the timing advances(to a point). To as much as Mid 40's BTDC.
Old Apr 15, 2011 | 11:11 AM
yeah i understand that a plugs fires right before it reaches tdc (the point where the air/fuel is ignited) and i wasnt really trying to relate it to anything on a map. i understand the timing moves for different events. i'm talk bacis physics like every action has a reaction. so u move btdc to a later event (retard) therefore the atdc event happens earlier (advance)
i think this is were im getting messed up. im thinking of a circle with the numbers going clock wise which would make what you wrote advanced because you made the compression stroke longer (by 5 degrees) because that would make it closer to 0 or tdc. i know im off somewhere.
i understand the more dense the air the less timing it needs (dense air burns faster). i'm jus confused on what side of the combustion event you actually pull from. so when you say i pull 5 degrees of timing does that mean i pulled from the before or after tdc
Old Apr 15, 2011 | 12:08 PM
ok so i did some more research and i think i may have found my answer. because you dont want the spark plug to fire to early on the compression stroke working to push the piston back down before it can make it to the power stroke (aka detonation). you add (pull) timing to the atdc so that the event happens later in the power stroke???
maybe i need to walk away for a couple of hours to clear my head and start back later hahaha
spoolingb20
Apr 26, 2006 10:46 AM
aron0903
Aug 4, 2004 12:34 AM
c-way
Jun 11, 2004 04:16 AM
gsrguy
Feb 7, 2004 02:10 PM
wrXtian
Mar 25, 2003 03:55 PM
