Timing issue help
Old Aug 24, 2006 | 11:22 AM
DC_RaceR's Avatar
Default Timing issue help
How do you adjust the timing for a DA b18a engine.
I place the light on but don't see the marking....
Old Aug 24, 2006 | 03:00 PM
Code's Avatar
Not now Chief, I'm in the F'n zone!
Default Re: Timing issue help (DC_RaceR)
Is the engine running while you're doing this?
Old Aug 24, 2006 | 03:09 PM
95 integra's Avatar
Default Re: Timing issue help (Code)
if he sees the light, then Im going to say yes. First familarize yourself with here the timing marks are on the crank pulley (look at it with a normal light), look for the arrow on the lower cover and then try it again.
Old Aug 24, 2006 | 06:41 PM
Rtzx9r's Avatar
GDD 1%
Default Re: Timing issue help (95 integra)
Not sure where it is, but you need to disconnet a wire, and then hook up the timing belt. Then adjust the distributor and check the timing. You cannot set it while the computer has control of the timing, hence the wire disconnect.
Old Aug 24, 2006 | 06:42 PM
Dartanian's Avatar
Is it connected to the #1 spark plug wire?
Old Aug 24, 2006 | 06:44 PM
95 integra's Avatar
Default Re: Timing issue help (Rtzx9r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtzx9r &raquo;</TD></TR><TR><TD CLASS="quote">Not sure where it is, but you need to disconnet a wire, and then hook up the timing belt. Then adjust the distributor and check the timing. You cannot set it while the computer has control of the timing, hence the wire disconnect. </TD></TR></TABLE>
I forgot all about that, the wire you need to jump is the same to check the CEL, its the blue plug under the glove box. I have been able to do it without jumping it in the past, but its never a bad idea to make double sure.
Old Aug 24, 2006 | 06:45 PM
DC_RaceR's Avatar
Where is that wire?
I read it somewhere said I need to jump the 2 prong connector in the car?
Where is this connector?
Modified by DC_RaceR at 8:03 PM 8/24/2006
the_tensl
Aug 7, 2014 03:27 PM
76 camaro car
May 17, 2011 12:00 AM
northemt88
Mar 15, 2008 12:57 AM
queez
Apr 14, 2004 01:09 PM
yakkosmurf
Dec 24, 2001 08:08 AM
