timing??
Old Apr 11, 2008 | 08:13 PM
turbo boost's Avatar
Default timing??
i just got my set up on the road..lsvtec,ramhorn garrett 60-1..81.5mm forged internals..im street tuning it now..i got the a/f between 11.5 and 12...7psi for now,till i get better at tuning...i have the base timing set to 16 degrees..and the ign retard to .9...is this fine?..or should i take more out for now?..im useing crome 1.4 with the timing fix added
just want to make sure..before i turn the boost up a bit more
thanks
Old Apr 11, 2008 | 08:28 PM
mtber's Avatar
Default Re: timing?? (turbo boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo boost &raquo;</TD></TR><TR><TD CLASS="quote">i just got my set up on the road..lsvtec,ramhorn garrett 60-1..81.5mm forged internals..im street tuning it now..i got the a/f between 11.5 and 12...7psi for now,till i get better at tuning...i have the base timing set to 16 degrees..and the ign retard to .9...is this fine?..or should i take more out for now?..im useing crome 1.4 with the timing fix added
thanks</TD></TR></TABLE>
Crome's timing number's really are not accurate. Do your self a favor & stay away from full throttle conditions until you are on a dyno & can monitor for signs of detonation. Honestly, I would suggest switching to eCtune, Neptune, Hondata :-P
Old Apr 11, 2008 | 10:30 PM
stockb18c's Avatar
you should be fine im on 18 degrees base timing on 9 psi you have alot of room to spare for power..
Old Apr 12, 2008 | 05:55 AM
Default Re: (stockb18c)
ok i have mine set at 16 degrees base and .9 ign retard..i thought that was pretty conservitive?..but i was just making sure?
Old Apr 12, 2008 | 06:05 AM
Default Re: timing?? (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
Crome's timing number's really are not accurate. Do your self a favor & stay away from full throttle conditions until you are on a dyno & can monitor for signs of detonation. Honestly, I would suggest switching to eCtune, Neptune, Hondata :-P</TD></TR></TABLE>
im just using free crome for now...i might switch over to ectune later on...but i was just wondering if my timing was on the conservitive side for now?..or should i take more retard/psi out?..id like to street tune it up to 10-12 psi for now?
thanks for the input
Old Apr 12, 2008 | 07:04 AM
97grnrs's Avatar
on my st tune i did i run .75 retard and 180% fuel boost compensation. i had .9 like u said and it was too much retard for my setup but yours is prob higher compression so may be ok for u .. just make sure its not popping or detonating..
Old Apr 12, 2008 | 10:56 AM
Default Re: timing?? (97grnrs)
bump
Old Apr 12, 2008 | 11:21 AM
welfarepc's Avatar
well u didnt tell us what kind of fuel you are using...
do some WOT pulls on the highway, turn off the engine at the top of your pull, pull over and read the plugs. if u see signs of detonation try to back off the timing. if not give it a tiny advance.
this was my plan but i ended up doing the smart and right thing and hit the dyno
well worth the $300
Old Apr 12, 2008 | 11:30 AM
Default Re: (welfarepc)
im using 91 octane..i plan on goin to the dyno..i just wanted to street tune it for now and get the a/f flatened out....and was just wanted to know if i had the timing on the conseritive side is all,till i hit the dyno to safly adj it
thanks
Old Apr 12, 2008 | 01:51 PM
Default Re: (turbo boost)
bump for some advice
Old Apr 12, 2008 | 05:58 PM
Old Apr 13, 2008 | 04:06 PM
any advice for a beginer tuner haha
Old Apr 13, 2008 | 06:31 PM
building boost's Avatar
.9 should be a good starting point. just make sure u look at the columns after you use the boost table adjustments because if u make changes to ignition retard, sometimes the resulting timing numbers come out all messed up.
if you absolutely aren't going to a dyno, make sure you pull plugs after any changes and check for detonation.
Old Apr 14, 2008 | 01:05 AM
Default Re: (building boost)
okie..detonation will look like spots...or peper on the end of the plugs rite?
Old Apr 14, 2008 | 11:59 AM
sewell94's Avatar
If you want the best advice for a beginner, read the quote above again
Old Apr 14, 2008 | 06:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo boost &raquo;</TD></TR><TR><TD CLASS="quote">okie..detonation will look like spots...or peper on the end of the plugs rite?</TD></TR></TABLE>
Old Apr 14, 2008 | 09:00 PM
yes, looks like specs and sounds like popcorn popping. there's a write up somewhere on here about reading plugs. it's pretty good. i really prefer s300 over crome though.
Old Apr 14, 2008 | 11:53 PM
98vtec's Avatar
moderator emeritus
post a screen shot of your timing maps
Old Apr 15, 2008 | 04:06 AM
Default Re: timing?? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">post a screen shot of your timing maps</TD></TR></TABLE>
its just a p72 map with .9 ign retard takin off..and the a/f between 11.5 and 12
im not sure on how to do a screen shot
Modified by turbo boost at 6:08 AM 4/15/2008
MonkeyBoy7805
11
Dec 2, 2010 11:38 AM
Nataku
Dec 27, 2006 07:04 PM
BoostedD15B7
Jan 25, 2004 08:44 AM
civictypenos
Oct 9, 2003 04:07 AM
wrXtian
Mar 25, 2003 03:55 PM
