where to set timing at?
Old Oct 8, 2003 | 04:27 AM
civictypenos's Avatar
Default where to set timing at?
t3,10 psi,b16a3.
im using bkr7e's gapped to .30,btm and crane igntion.
stock timing is the red mark in the middle right?14?i have the btm set to .33 retard,should i bump up my timing some?
whats better,advance base timing and retard the btm more,or run stock timing with minimal btm ?
right now its set to the red mark in the middle of the 2 white ones.
Old Oct 8, 2003 | 06:19 AM
ScottEK's Avatar
Default Re: where to set timing at? (civictypenos)
I think you'd probably want to leave your base timing stock, just an FYI, the red mark in the middle is 16 degrees.
Old Oct 8, 2003 | 06:53 AM
Default Re: where to set timing at? (beta13)
ok,thanx.
i was asking becuase i saw someone who had their base timing at 21 and the btm at 1 deggree per psi.
Old Oct 8, 2003 | 05:39 PM
anyone else want to comment?
Old Oct 8, 2003 | 07:10 PM
scttydb411's Avatar
on my d-series i just kept it stock...didn't mess with it at all and run .33/lb pulled with btm. i run the hack so it supposedly advances timing on the low throttle, but no probs there and it feels better off boost.
Old Oct 8, 2003 | 07:51 PM
InTeGrA B18b1's Avatar
did you guys feel a difference with and without the btm? or just a safety precaution?
Old Oct 9, 2003 | 04:07 AM
Default Re: where to set timing at? (InTeGrA B18b1)
dunno,ihave had it one since day one witht he boost.
civic j
Aug 17, 2007 08:10 AM
c-way
Jun 11, 2004 04:16 AM
wrXtian
Mar 25, 2003 03:55 PM
