Tial Wastegate stuck open
Alright, so i just recently got my car running after going boost. Well i noticed that at idle exhaust is coming out of my dumptube. I took the dumptube off and sure enough the WG is stuck open.
I bought it used from a member on here. The valve seat is in, i just checked. It is only open about half a cm. I can't get the valve to move up or down when i press on it.
I am going to take apart the WG tomorrow. Anything i should look for? What normally causes this? Faulty WG?
Thanks.
Thanks.
do you have your vacum source hooked into the top or the bottom of the WG ? if its in the top. the valve might open @ idle with a very low psi rated spring in the gate.
sounds like someone used leaded fuel with a pump valve
look for corrosion on the valve stem, or the sweet sweet smell of race gas
Modified by TiAL at 7:06 AM 6/11/2007
