Tial wastegate problem
Old Oct 31, 2003 | 02:30 PM
  #26
30psi Teg's Avatar
Default Re: Tial wastegate problem (japspec)
Do you have your wastegate seeing boost off the compressor housing??? if so then it could just be pressure drop from the IC. First I would try plugging the compressor vacum port and running a vacum line from intake to the wastegate and see if pressure drop from IC is the problem if not then you have to have an exhaust leak or leak in the piping or intake.
Old Oct 31, 2003 | 02:48 PM
  #27
japspec's Avatar
Default Re: Tial wastegate problem (30psi Teg)
exhaust leak like where the dp meets the cat or where the dp meets the turbo.
Old Oct 31, 2003 | 02:55 PM
  #28
30psi Teg's Avatar
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspec &raquo;</TD></TR><TR><TD CLASS="quote">exhaust leak like where the dp meets the cat or where the dp meets the turbo. </TD></TR></TABLE>
no the leak would be before the turbo like on your manifold or where the turbo bolts to the manifold or the wastegate may have loosend and its leaking from there
Old Oct 31, 2003 | 03:38 PM
  #29
japspec's Avatar
the wastegate loosened once cause gasket had got blown out could that be why im losing 2 lbs of boost. When gasket was there i was gettting 7.25
Old Oct 31, 2003 | 03:54 PM
  #30
Full-Race Henry's Avatar
Where is the Vac line from the WG connected to?
Old Oct 31, 2003 | 06:18 PM
  #31
30psi Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspec &raquo;</TD></TR><TR><TD CLASS="quote">the wastegate loosened once cause gasket had got blown out could that be why im losing 2 lbs of boost. When gasket was there i was gettting 7.25</TD></TR></TABLE>
no you wouldnt lose 2psi from that. That is exactly how I run mine. My guess is either A) IC pressure drop or B) Exhaust leak somewhere before turbo. It could be a leak somewhere in the intake but it would have to be decent size because the low boost you are running the turbo would be able to make up the difference for a small leak. I am gonna say IC pressure drop, so try running the wastegate vacuum line to a good spot on the intake manifold and see if that fixes it.
Old Oct 31, 2003 | 06:28 PM
  #32
Bailhatch's Avatar
did you replace the gasket yet? if the anwser is 'no' then.......someone else will explaine.
Old Nov 2, 2003 | 04:56 PM
  #33
japspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psi Teg &raquo;</TD></TR><TR><TD CLASS="quote">
no you wouldnt lose 2psi from that. That is exactly how I run mine. My guess is either A) IC pressure drop or B) Exhaust leak somewhere before turbo. It could be a leak somewhere in the intake but it would have to be decent size because the low boost you are running the turbo would be able to make up the difference for a small leak. I am gonna say IC pressure drop, so try running the wastegate vacuum line to a good spot on the intake manifold and see if that fixes it.</TD></TR></TABLE>
I thought you always run the hose from wastegate to the side of the turbo compressor.
Old Nov 2, 2003 | 04:58 PM
  #34
japspec's Avatar
Default Re: Tial wastegate problem (EF8_Fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8_Fan &raquo;</TD></TR><TR><TD CLASS="quote">Where is the Vac line from the WG connected to?</TD></TR></TABLE>
It is connected to the side of the turbo housing
Old Nov 3, 2003 | 05:15 AM
  #35
30psi Teg's Avatar
I thought you always run the hose from wastegate to the side of the turbo compressor. </TD></TR></TABLE>
You can but you dont have to. The problem with running it to the compressor housing is that you are getting pressure before the intercooler well as is the case with most peoples intercoolers you will have pressure drop after the IC so it is better to run the wastegate line into the intake mani. so that you are getting a true 7.5 psi and not losing some b/c of pressure drop.
Old Nov 3, 2003 | 06:20 AM
  #36
VTC_CiViC's Avatar
Default Re: (ffgeon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ffgeon &raquo;</TD></TR><TR><TD CLASS="quote">pressure drop from ic? </TD></TR></TABLE>
I can't belive it took this many posts for somebody to finally mention that..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You can but you dont have to. The problem with running it to the compressor housing is that you are getting pressure before the intercooler well as is the case with most peoples intercoolers you will have pressure drop after the IC so it is better to run the wastegate line into the intake mani. so that you are getting a true 7.5 psi and not losing some b/c of pressure drop.
Bingo
Old Nov 3, 2003 | 09:04 AM
  #37
Marauder's Avatar
It is connected to the side of the turbo housing</TD></TR></TABLE>
Connect it to the intake manifold!
Old Nov 4, 2003 | 07:35 PM
  #38
japspec's Avatar
Default Re: Tial wastegate problem (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">
Connect it to the intake manifold! </TD></TR></TABLE>
where on the manifold is the best place to hookup vacuum on manifold.
Old Nov 5, 2003 | 07:12 AM
  #39
Marauder's Avatar
For the wastegate, I'd get a Tee and hook it to the brake booster line.
Old Nov 5, 2003 | 07:18 AM
  #40
30psi Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">For the wastegate, I'd get a Tee and hook it to the brake booster line.</TD></TR></TABLE>
Old Nov 5, 2003 | 07:25 AM
  #41
Marauder's Avatar
btw....the brake line is most likely a 10mm line...so you would need a Tee with the main size as a 10mm...and the side port the size of your wastegate line.
Old Nov 5, 2003 | 04:11 PM
  #42
japspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">btw....the brake line is most likely a 10mm line...so you would need a Tee with the main size as a 10mm...and the side port the size of your wastegate line.</TD></TR></TABLE>
is it safe to tee it off the brake booster
thegatekeeper14
Aug 17, 2009 12:39 PM
teamcalloway08
Jul 25, 2009 08:25 AM
99TurboFerio
Jun 6, 2005 12:15 AM
RedTegLS
Dec 10, 2003 12:30 PM
turbob18a1
Apr 20, 2003 09:52 PM
