Boosting too high!!
Old Dec 10, 2003 | 10:23 AM
RedTegLS's Avatar
Default Boosting too high!!
I was just out ripping around and trying to pay attn to my boost gauge. The wastegate I have is the one that comes in the Spark kit springed for 8.7lbs. When I get the turbo spooled up it boosted to 15lbs!!!! No detonation and it did not go lean. I am wondering if the gauge is wacked or what? If it was spiking it wouldnt do it everytime would it? Help me out. Thanks.
Old Dec 10, 2003 | 10:26 AM
30psi Teg's Avatar
Default Re: Boosting too high!! (RedTegLS)
well are you tuned past 9 psi if so I doubt youd have detonation. Check the gauge, check your lines to make sure they are clean and not kinked (mainly the lines going to the wastegate.) Yes, if it is spiking it should do it everytime unless the wastegate is just sticking closed for a sec. Does it come back down or keep rising?
Old Dec 10, 2003 | 10:30 AM
RedTegLS's Avatar
Default Re: Boosting too high!! (30psi Teg)
At this point in time its untuned with a really good basemap only. The car idles perfect and never goes too lean. The boost gauge constatly rises from 5 - 14 or 15 and stays right there. I dont know how long it stays there becuase I shift it at 5300-5500 as advised based on not being tuned.
Old Dec 10, 2003 | 10:41 AM
30psi Teg's Avatar
Possibly a shitty wastegate, you sure its not a 14 pound spring.
Old Dec 10, 2003 | 10:43 AM
RedTegLS's Avatar
The spring would mke sence but I was told by the place I bought it from its a 8.7lb spring. OK so basically buy a Tial, huh?
Is there anything else that might be causeing this?
Old Dec 10, 2003 | 10:48 AM
30psi Teg's Avatar
Other than a possible kinked line.
Also something I just thought of you said that you are untuned it could be a combination of too much ignition retard and too much fuel doing that but I seriously doubt it would spike that high.
Anyway just buy a tial.
Old Dec 10, 2003 | 10:51 AM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote"> The wastegate I have is the one that comes in the Spark kit...</TD></TR></TABLE>
What brand is it? I've never had ANY prob's with my Tial..
Old Dec 10, 2003 | 10:54 AM
RedTegLS's Avatar
Default Re: Boosting too high!! (glowing_turbo)
I know I know Tial is the shiz but I was hoping to wait till after xmas to buy one. How can this wastegate be spiking it has 87 miles on it!
Old Dec 10, 2003 | 11:27 AM
30psi Teg's Avatar
it could just be bad placing on the manifold you said you have a spark racing kit does your manifold look like this by chance.
Old Dec 10, 2003 | 11:35 AM
racinskittle's Avatar
creep. What kinda mani?
Old Dec 10, 2003 | 11:40 AM
RedTegLS's Avatar
Default Re: Boosting too high!! (racinskittle)
Nope this is my engine bay here.........
Old Dec 10, 2003 | 11:50 AM
30psi Teg's Avatar
yep bet its the manifold they put the wastegate in a shitty spot causes a lot of boost creep.
Hell mine will hold 14 psi till about 5500rpm then rises from there to 30psi at redline.
Old Dec 10, 2003 | 12:26 PM
Happyman's Avatar
Default Re: (30psi Teg)
I'll sell ya my tial ^_^ 200 shipped with dump tube. .65 bar spring(9 psi)
Old Dec 10, 2003 | 12:30 PM
Rory Breaker's Avatar
What exhaust are you running? I was having similar problems due to my Drag mani and open DP.
thegatekeeper14
Aug 17, 2009 12:39 PM
aznkr4zyboi
Mar 12, 2009 11:44 AM
99TurboFerio
Jun 6, 2005 12:15 AM
paulzy
Dec 23, 2001 05:47 PM
