InlinePro Manifold and Tial Wastegate
Old Dec 13, 2003 | 08:29 AM
blumeany's Avatar
Default InlinePro Manifold and Tial Wastegate
Hey guys, I've been tinking of getting an inlinepro manifold but I've heard that there are clearance issue with regards to the Tial and dumptube. Is this true and if so which wastegate to use? Anybody got any pics of there setups?
Thanks in advance
Old Dec 13, 2003 | 08:34 AM
Ri5e's Avatar
Default Re: InlinePro Manifold and Tial Wastegate (blumeany)
That's why InlinePro stock Turbosmart wastegates now, because the Turbosmart wastegates are shorter and they don't have the fitting at the top
You could use the Tial with no problem if you are not using that fitting at the top or you can get an elbow to make the Tial lay down sideways
Old Dec 13, 2003 | 08:57 AM
B18Flip's Avatar
Default Re: InlinePro Manifold and Tial Wastegate (BG Boost)
If i remember correctly,i think the clearance issue was only only on G3 integra's
Old Dec 13, 2003 | 09:22 AM
alpha's Avatar
I think he is talking about the dump tube clearing the A/C lines. Yes it's a pain in the *** as you can tell from the pictures. There is no A/C due to this problem.
http://f1.pg.photos.yahoo.com/...hotos
If the link doesn't work right click copy shortcut and paste it into your browser.
<edit>
You can buy an elbow or take a little more time on the fabrication.
</edit>
jtracing919
Jan 21, 2006 06:24 PM
kabaroo
Jan 4, 2005 01:45 PM
f1 vtec
Apr 29, 2004 04:53 AM
NyQuiL
Jul 15, 2003 11:14 PM
