Tial 40mm wastegate spring question
Can anyone verify what bar the large yellow spring is? I thought it was
.8 or .9 bar, I did some searches on here and I seen .45 bar. I just wondered
if it was for the small spring or large spring. Also you can only boost as much
as twice the spring rate correct?
Re: Tial 40mm wastegate spring question (Mikes01GSR)
Heres all you need. Put it in your notepad. Bottoz posted this some time ago.
Here are the spring pressures and colors:
35mm TiAL / spring discription
.3 bar / 4.35psi / <FONT COLOR="yellow"> small yellow</FONT>
.45 bar / 6.53psi / <FONT COLOR="red">small red</FONT>
.65 bar / 9.43psi / <FONT COLOR="green">small green</FONT>
.8 bar / 11.6psi / <FONT COLOR="blue">small blue</FONT>
35mm TiAL HP (35mm bottom + 40mm top)
.95 bar / 13.78 / <FONT COLOR="yellow">big yellow</FONT>
1.1bar / 15.95psi / <FONT COLOR="red">big red</FONT>
1.35bar / 19.58psi / <FONT COLOR="green">big green</FONT>
1.5bar /21.75psi / <FONT COLOR="blue">big blue</FONT>
40mm TiAL
.25 bar / 3.63psi / <FONT COLOR="yellow">small yellow</FONT>
.4 bar / 5.80psi / <FONT COLOR="red">small red</FONT>
.5 bar / 7.25psi / <FONT COLOR="green">small green</FONT>
.6 bar / 8.70psi <FONT COLOR="blue">small blue</FONT>
.7 bar / 10.15psi / <FONT COLOR="yellow">big yellow</FONT>
.8 bar / 11.60psi / <FONT COLOR="red">big red</FONT>
.9 bar / 13.05psi / <FONT COLOR="green">big green</FONT>
1.0 bar /14.50psi / <FONT COLOR="blue">big blue</FONT>
40mm TiAL HP (combine big and small springs to get desired output)
40mm TiAL
Re: Tial 40mm wastegate spring question (93LSivic)
Awesome guys I really appreciate it, wonder why I didn't see that when I searched. Notepad material for sure!!
mike what springs do you have?
all of these?
might be interested in one that your not using
mike
you really need to get ahold of me sometime...
when are you leaving to get dyno tuned?
all of these?
mike
Re: Tial 40mm wastegate spring question (kaneda3)
actually
nevermind just pulled mine apart and saw that it already has the spring i was going to ask you for...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic »</TD></TR><TR><TD CLASS="quote">Heres all you need. Put it in your notepad. Bottoz posted this some time ago.
40mm TiAL
do these apply also to a 38mm tial wastegate?? good ****
40mm TiAL
aquarius
05-04-2007 04:01 AM
sPaRk'iT
09-10-2004 10:16 PM
