checking engine codes but getting Solid constant CEL... DEAD ECU?
Old Oct 2, 2006 | 01:50 PM
drumminforev's Avatar
Default checking engine codes but getting Solid constant CEL... DEAD ECU?
I jumped the two pin connection with a solid copper wire. I get constant cel no blink nothing. as soon as i unplug it goes back to normal no cel. Is this a dead ecu or a no problem ecu. I wouldnt be suprised if its dead ecu cuz i get 18mpg city.
Would the car still drive with a dead ecu....any other way to verifiy
Old Oct 2, 2006 | 03:34 PM
nsxmatt's Avatar
No problems or codes.
Old Oct 2, 2006 | 03:35 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (nsxmatt)
Are you doing this with the car started and on?
You should jump the wire with the car off, then turn the key to the run position, but do not start it. Then it will flash the codes, if you have any.
Old Oct 2, 2006 | 10:43 PM
Default Re: (JDM_Ej)
this is with the car off and put in the ON position. so my ecu has no codes? are u sure it just isnt blown ecu. i am hoping so and hoping thats the root of my problems....
Old Oct 2, 2006 | 11:01 PM
Default Re: (drumminforev)
is it blown or just no codes.
what would be a sign of a blown ecu that still drove the car
Old Oct 3, 2006 | 08:47 AM
my thermostat grounds are good
Old Oct 3, 2006 | 09:04 AM
Luserkid's Avatar
Well then.... whats the car doing? Do you get a light while your driving and then when you jump it its still solid, then thats a bad ecu. If you have no codes and you jump it and get a solid then you have no codes.
Old Oct 3, 2006 | 10:41 PM
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Well then.... whats the car doing? Do you get a light while your driving and then when you jump it its still solid, then thats a bad ecu. If you have no codes and you jump it and get a solid then you have no codes. </TD></TR></TABLE>
Thats not what i have been reading. I have no codes when driving, but my a/f are whack and i dont know what else it would be. I run so rich you can barely breathe inside the car from emissions. Plus i get 18mpg city 34mpg hw
"Solid Check Engine Light
If the CEL is lit solid and does not blink <u>(after jumping the service check connector on OBD1 )</u> and the car runs poorly the following could be the problem:
* A faulty ECU (means any other component failure other than listed here)
* Poor soldering connections
* Check Sum error
* Faulty program stored in the ROM
* Faulty ROM chip
* Faulty 74HC373 chip"
From http://www.pgmfi.org/twiki/bin/view/Library/CEL
Why does that say the exact opposite of what you said.
Old Oct 3, 2006 | 10:43 PM
and its not chipped, (t0 my knowledge)
Old Oct 3, 2006 | 10:44 PM
Luserkid's Avatar
Do you have a wideband or are you looking at the light show a/f gauge?
How does the car run? If its driving fine then you have no problems. If its running like crap then its a bad ecu. Not that hard to tell when an ecu is bad. Try another one and see how it goes.
Old Oct 3, 2006 | 10:45 PM
Default Re: checking engine codes but getting Solid constant CEL... DEAD ECU? (drumminforev)
Someone with obd1 that has NO CODES go jump your ecu and tell me if its solid cel when jumped...
Old Oct 3, 2006 | 10:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a wideband or are you looking at the light show a/f gauge?
How does the car run? If its driving fine then you have no problems. If its running like crap then its a bad ecu. Not that hard to tell when an ecu is bad. Try another one and see how it goes. </TD></TR></TABLE>
I have no af gauge. I just know they are wack because i get 200 miles to a 9 gallon tank.
The car drives fast as hell. However, it sputters at complete random when taking off off the line. Only about 2-4 sputters, and only when taking off off the line.
Old Oct 3, 2006 | 10:51 PM
Luserkid's Avatar
Ever heard of a tune up? you know if you keep your car well maintained youll get good gas mileage. try a full tune up.
Old Oct 3, 2006 | 10:58 PM
Suck my DX's Avatar
a blown ECU fuse gave me a solid CEL recently
Old Oct 3, 2006 | 11:01 PM
Crank's Avatar
Default Re: (Suck my DX)
fried ecu. stick another ecu in there and try it out
Old Oct 5, 2006 | 10:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Ever heard of a tune up? you know if you keep your car well maintained youll get good gas mileage. try a full tune up. </TD></TR></TABLE>
Done it, slicks.
Well if anyone has a p30 ecu for sale virgin unless its already tuned then im lookin to buy
Old Oct 5, 2006 | 10:04 AM
anyone have an idea what can cause low end sputtering
Old Oct 5, 2006 | 12:02 PM
Suck my DX's Avatar
BAD 02 SENSOR
Old Oct 5, 2006 | 08:44 PM
i just replaced it
Old Oct 6, 2006 | 12:12 AM
imjustakid's Avatar
check timing belt it might stretched out because it's old. i've had some of those probs before
h0nda n00b
Engine Management and Tuning
Feb 27, 2014 09:13 AM
jpar195
Apr 7, 2008 12:01 PM
