real fast ecu question
Old 05-16-2013, 09:56 PM
rizzuto's Avatar
Default real fast ecu question
i have a p07.. that is showing code 0...guessing its my ecu... can i use a p08 ecu to see if i still get code 0? as long as i dont try to start it ? just wanna know it if my ecu or if i have a short where i jump the wire
Old 05-16-2013, 10:33 PM
jdmkid808's Avatar
Default Re: real fast ecu question
are you sure its code 0??
Old 05-16-2013, 10:35 PM
rizzuto's Avatar
cel is on at all times jumped or not but it still runs so think code just ant getting sent or ecu is messed up somehow
Old 05-17-2013, 03:09 AM
The Grumpiest
grumblemarc's Avatar
Could have tried it by now.
Old 05-17-2013, 03:12 AM
B_Swapped93's Avatar
lol^ agreed. but yes solid CEL=0 (ECU/ECM) replace it
Old 05-17-2013, 05:23 AM
sleepyaccord96's Avatar
yep sounds like it may be as fried as a nugget from mcdonalds...
Old 05-17-2013, 05:44 AM
Former User's Avatar
Check for a short in the brown service connector wire.
Old 05-17-2013, 09:59 AM
rizzuto's Avatar
i was just wondering if the p08 would mess anything up... pretty sure its just d16 insted of d15
Old 05-17-2013, 10:09 AM
Oh look, I can change this
deschlong's Avatar
This. Could also mean a prob with the wire vs. actual ECU.
Old 05-17-2013, 11:29 AM
for as cheap as the oem ecu's go for i say replace the ecu with a known good unit.
Wire shortage is possible but i highly doubt it unless something has been done near the ecu wiring loom/harness recently.
Old 05-17-2013, 11:32 AM
deschlong's Avatar
As a rule, always diagnose a problem to the best of your ability before throwing parts and money at possible solutions.
Old 05-17-2013, 01:11 PM
rizzuto's Avatar
how do i check for short in it... not to good with electronics ... i have a digatal molta meter
tlarimer's Avatar
Already covered this with OP in the other thread:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/need-help-asap-bogging-4k-3146143/
He has got Code 0, but the car starts, I advised he check ecu ground and for a short in the service connector as per the FSM.
Old 05-17-2013, 01:18 PM
rizzuto's Avatar
^pretty sure there good but not really sure if i check them right -_-
Old 05-17-2013, 07:59 PM
Use a multimeter to test whether the wire has continuity to body ground (=short).
O RLY
10
07-02-2007 07:28 AM
VTECth1s
08-03-2006 01:01 PM
MelloYelloCRX
07-22-2006 05:17 PM
ef_you_again
03-17-2005 11:14 PM
didyouhearthat
02-08-2004 08:06 PM
Quick Reply: real fast ecu question
