TDO5H ?
Old Nov 8, 2001 | 05:57 PM
00b18b's Avatar
Default TDO5H ?
i just picked up this turbo but i dont know much about it. can some1 tell me the specs, capablity, etc etc.. it has tdo5h stamped on it.
o yeah this is used how can i clean it? what do i need to do to make work? cuz the impeller or whatever doesnt spin.
Old Nov 8, 2001 | 06:40 PM
immortal's Avatar
Banned
Default Re: TDO5H ? (autoLS)
18G?
Old Nov 9, 2001 | 02:19 AM
00b18b's Avatar
Default Re: TDO5H ? (immortal)
how do i find if its 18g? is it stamped somewhere on it?
Old Nov 9, 2001 | 05:42 AM
rtype11's Avatar
stock talon isnt it??? 16G, if it dont spin its probably spun!!!!!!!!!!!!!!!!
Old Nov 9, 2001 | 05:43 AM
b18bturbo's Avatar
its not good to spin the compressor with no oil in it.. its probably fine a turbo if the shaft ans no movement in it.
Old Nov 9, 2001 | 06:05 AM
VTC_CiViC's Avatar
Default Re: TDO5H ? (b18bturbo)
The 2G Eclpses used T25's, so that can't be outta that. 1G's used a 14B which I belive used a TD05 housing, so that's probably what you have. Swap out the wheel for a 16G or Super 16G for power upper end power and easy spool. When I first picked up my TD04, it spun but with alot of resistance since it had no oil, as long as there's no shaft play it should be fine.
Old Nov 9, 2001 | 03:33 PM
00b18b's Avatar
Default Re: TDO5H ? (VTC_CiViC)
i was messing with it alittle trying to clean it and the exhaust housing came off exposing the impeller. what went wrong there? is there suppose to be clips, screws, or something that holds these two parts together?
Old Aug 18, 2003 | 12:10 AM
lilblacksol's Avatar
Default Re: TDO5H ? (00b18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00b18b &raquo;</TD></TR><TR><TD CLASS="quote">i was messing with it alittle trying to clean it and the exhaust housing came off exposing the impeller. what went wrong there? is there suppose to be clips, screws, or something that holds these two parts together?</TD></TR></TABLE>
I know this is old but I did a search, found this, and was wondering the same thing
umair
Nov 16, 2013 05:42 PM
si0385.
Oct 15, 2006 01:14 PM
huge230
Mar 27, 2006 03:35 PM
AF-b16a1
Sep 27, 2004 10:05 PM
JalopySiR
Apr 23, 2003 10:45 AM
