Tap wrench?
Old Apr 22, 2002 | 12:10 PM
Trac226's Avatar
Default Tap wrench?
Can anyone explain to me how to use a tap wrench for the oil pan?
Old Apr 22, 2002 | 12:43 PM
apexii's Avatar
Default Re: Tap wrench? (Trac226)
Well, do you need to re-tap any of the oilpan bolt holes?
I was under the impression that a tap wrench was a wrench used for tapping new threads.
Old Apr 22, 2002 | 02:40 PM
inspyral's Avatar
Default Re: Tap wrench? (apexii)
Maybe he's tapping for a drain fitting...
Old Apr 22, 2002 | 02:51 PM
simike's Avatar
Default Re: Tap wrench? (inspyral)
A tap wrench is used to hold a tap. The tap is what does the cutting. You can use a tap to retap a hole if the threads are messed up, or the main use of a tap is cutting threads in a hole that has just been drilled. When people say they tapped there oil pan they usually mean for the oil return line in which they screw in a fitting to recieve the oil line.
Old Apr 22, 2002 | 03:02 PM
intekragsr's Avatar
how much do these tools cost? i am about to go buy some
Old Apr 22, 2002 | 03:15 PM
simike's Avatar
Default Re: Tap wrench? (intekragsr)
It all depends on what you want. Tap wrenches come in all differant sizes. The taps also come in every thread size you can think of. For one tap handle and one tap maybe $10- $20. Just make sure the tap you buy fits the handle or vise versa. You might be able to find a set of taps and dies for a good price say $50-$80. They come with all metric or all standard taps and dies including handles.
Old Apr 22, 2002 | 06:32 PM
Trac226's Avatar
Default Re: Tap wrench? (simike)
I get it now, thanks for the info guys...learning more all the time from this place. I guess i don't need the taps or the wrench then, just need to drill my holes for the oil return flange right? (yeah, i know, i should get it welded)
Mr. Samurai
Feb 26, 2005 09:48 PM
aracer69
Sep 9, 2003 02:04 PM
DIY_Racing
Dec 20, 2002 09:39 AM
ion_four
Aug 2, 2002 02:30 PM
Evil EG
Apr 3, 2002 07:30 PM
