take off fuel pump/fpr w/ hondata?!?
Old 01-30-2002, 05:17 PM
New User
threatcon13's Avatar
Default take off fuel pump/fpr w/ hondata?!?
when i got my car back from my hondata tuner..i noticed he had removed my vortech fmu and fuel pump...(he installed dsm 440s) i asked him about this and he said that theyre not needed anymore w/ the hondata..is this true ?
Old 01-30-2002, 05:28 PM
New User
Xerxes's Avatar
Default Re: take off fuel pump/fpr w/ hondata?!? (turbo01gsr)
you don't need the FMU but i'd keep the FPR and Fuel pump.
-Xerxes
Old 01-30-2002, 05:30 PM
New User
smoothludey2's Avatar
Default Re: take off fuel pump/fpr w/ hondata?!? (Xerxes)
was it an aftermarket fuel pump? I don't understand...hondata is just the ecu, it doesn't help with the fuel at all.
New User
neither vortech or stock is on there anymore
Old 01-30-2002, 05:35 PM
New User
how can you run your car without a fuel pump? was the vortech intank or inline?
Old 01-30-2002, 05:38 PM
New User
Default Re: take off fuel pump/fpr w/ hondata?!? (smoothludey2)
actually hondata controls delivery rate and amount of fuel delivered. it was the vortech FMU that came with the drag 3 kit, as well as the airtex inline fuel pump. my car gets fuel now via the stock fuel pump...the inline is a supplement to the stock fuel pump.
Old 01-30-2002, 05:40 PM
D-SPEED's Avatar
the purpose of your FMU is to rise fuel pressure under boost, resulting in more fuel passing through the injector. With a hondata and larger injectors, you are able to provide the needed fuel without high fuel pressures. I dont know if you had an inline or intank pump, but the inline pump is not needed anymore because it no longer needs to support high fuel pressures. I think you can get away with the stock intank pump, but i decided to go with a walbro 255 lph high pressure intank pump.
Old 01-30-2002, 05:42 PM
New User
Default Re: take off fuel pump/fpr w/ hondata?!? (D-SPEED)
sounds good! thanks...I am planning on going with the walboro as well.
Old 01-30-2002, 08:37 PM
RH+G's Avatar
I think you meant the Walbro low pressure in tank pump with hondata.
Old 01-30-2002, 08:41 PM
Better than steak
Arturbo's Avatar
Default Re: take off fuel pump/fpr w/ hondata?!? (RH+G)
I would still go with the walbro high pressure.
art
Old 01-30-2002, 08:46 PM
dustin's Avatar
Default Re: take off fuel pump/fpr w/ hondata?!? (Arturbo)
I, too, would run an aftermarket intank fuel pump with your setup. The stocker just can't flow enough safely.
Dustin
Dee
Dee's Avatar
nope.. he was correct when he said High psi Walbro. Walbro GSS 342 is the way to go when using a Hondata.
Old 10-28-2003, 01:59 PM
wrestler121's Avatar
Default Re: take off fuel pump/fpr w/ hondata?!? (Dee)
I'm piecing together my turbo set up...do i NEED a fpr with hondata and an aftermarket intake pump or is it just a nice thing to have? I know I'd need one with a FMU but do i need one for hondata intake pump setup?
Stewart
Old 10-28-2003, 09:13 PM
Dee
Dee's Avatar
Default Re: take off fuel pump/fpr w/ hondata?!? (wrestler121)
With a Hondata a good fuel pump (Walbro or Bosch) and an FPR is needed.
With an FMU, Walbro pumps are not recommended because the fp's will constantly go over 80psi and cause some serious fuel starvation problems.
FMU = Bosch + FPR
stand alone ecu = any good pump + FPR
Holley and BBK intank units are rebadged Walbro's.
Turbocivic94
06-01-2004 03:04 PM
JustAnotherHonda
09-08-2003 03:35 PM
gsr sol
08-29-2002 09:18 AM
CM-R
06-21-2002 11:34 AM
97GSRT
03-28-2002 04:21 AM
Quick Reply: take off fuel pump/fpr w/ hondata?!?
