supercharged Ep3 10 psi
Old Nov 20, 2008 | 07:33 PM
GSR_Hatch711's Avatar
Icon2 supercharged Ep3 10 psi
is it true that the factory sensor on the tb will only allow around 10 psi even though my pulley is good for 12 psi... and untill i up grade that sensor i will get the 12 psi out my pulley? ep3 put down 210whp 10psi on kpro
Old Nov 21, 2008 | 04:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
stupid question, but are you talking about a jackson s/c? if so, the map on the tb wont see boost as it is before the supercharger.
Old Nov 21, 2008 | 08:11 PM
rmcdaniels's Avatar
The sensor won't affect the boost, you'll make as much as you have the pulleys for, but your ECU will only see as much as the sensor can register, which I think is 10-11 for a Honda sensor.
Old Nov 21, 2008 | 08:19 PM
HiProfile's Avatar
If your know it will be a fixed 12psi, you can still use your stock MAP, which barely reads past 11psi. For all it cares, 40psi is the same as 11psi, same as 12psi will be reported to the ecu as 11psi. If you run the 11psi fuel column a bit rich, you will get away with it being at 12psi. 10psi with be fine, 11psi will be rich, and 12psi will probably be fine. One thing to note, some cars make more boost, some less, on the same pulley.
Old Nov 22, 2008 | 05:45 PM
daveb91's Avatar
But it matters where the map is plumbed into. It can be plumbed after the blower which will see boost. I think he is confused. Most say the stock map is good to around 11psi. i think thats what he meant.
Old Nov 22, 2008 | 05:46 PM
daveb91's Avatar
Sorry just saw the RMCdaniel just answered half of that.
Old Nov 24, 2008 | 07:58 AM
i jus thought if i were to upgrade that map sensor i would get the 12psi the pulley claims for extra power instead of 10
MethHeadCrx
Jun 19, 2015 03:22 AM
4dek
Jul 3, 2008 08:31 PM
B16Drag
Jan 25, 2006 06:59 AM
b18cya
Apr 16, 2003 02:29 PM
MindEracer
Jul 5, 2001 09:38 AM
